Home > Maintenance & Mods (L322) > Rear wheel arches FFRR 12
EmiratesA380
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Aintree Green
Re: Rear wheel arch protection / inner arch
In case this helps anyone just replaced my rear wheel arch rubber protection.
Sourced it from:
http://www.ebay.co.uk/itm/RUBBER-BLACK-CAR...1c4567ff1a
hope this helps anyone
Post #352352 15th Oct 2015 9:49am
Strider
Looks a good fix Thumbs Up ,
I've noticed on my rear arches a slight discolouration starting on the edges.
The existing door rubber only overlaps about 50% of the arch return bend leaving the remainder exposed to the elements.
Does it catch on the door rubber when the door is closed?
Peter
Post #352355 15th Oct 2015 10:10am
EmiratesA380
Hi Peter
On both cars it does not - having said that the rubber that was the original LR stuff ( good stuff ) - had bent into various shapes
I was careful in removing it - I think the winter crap had deformed the metal inside.
A point worth looking at is another post I have added a few minutes ago - again this might be helpful to you
Rear wheel arches Report post
Just to add to these good winter points
I have sprayed Hammerite BLACK wax oil IN LIP & ON LIP EDGES of both rear wheel arches - with a new black protective rubber strip on both FFRR ready for winter
to help with spraying I usually add 10% white spirit to the Hammerite pressure sprayer can to help get consistent flow - hardens after 1 hour
again hope this helps with ideas
all the best
Post #352357 15th Oct 2015 10:21am
Strider
Hi,
thanks for the information, also the other post was very interesting. The safety comment about not relying on the air suspension good point, oops.
I did exactly that when i got the car this year, I went underneath to take pictures of the suspension, my old classic just had coils and live axles, this set up is a whole new experience.
Peter
Post #352370 15th Oct 2015 1:47pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
How many meter's you order ? thanks paul
Post #352422 15th Oct 2015 7:46pm
EmiratesA380
Hi Paul
the old ones measured 430mm in length each ( that's on a 4.4 TDV8 12 plate ) not sure if 07 - 10 year are different ? - worth checking but should be the same
again hope this is helpful
Post #352440 15th Oct 2015 9:13pm
EmiratesA380
Strider wrote:
Hi,
Hi Peter
Have a look at when the cars on the lowest suspension setting - there's not much clearance for you if you were under her !!!!! - I am sure they have a mind of their own
Good luck with yours if you decide to do it -
Post #352443 15th Oct 2015 9:18pm
dhallworth
These were fitted to the Freelander as standard and can be bought from Dan @ Duckworths. They're also fitted to our 2012 from the factory so should also be available.
My post on here (2nd to last) has the part number for the strip from the Freelander that appears to be the right length.
http://www.fullfatrr.com/forum/viewtopic.php?p=351757#351757
Post #352474 16th Oct 2015 12:20am
pld118
I'm going to upgrade the rubber rear arch trims on our 2012. Theyre genuine LR/ arches are not affected by rust.
Was it not rightly pointed out in previous posts that the rubber strips with metal in them can contribute to corrosion?
If so, with our former SC and based on forum rec's I accorded with the following, which worked a treat:
nicedayforit wrote:
I've used the door edge protector shown below on the wheel arch return flange. Had it on a couple of years up to now. Before fitting I cleaned the flange on both faces and applied a liberal coating of black grease to each face, fitted the protector strip and cleaned off the excess grease. Just took the strips off recently to clean, regrease and refit. The flanges are like new. Done my daughters Freelander the same way instead of using the LR replacement part. IMO the plastic strip is better than the LR strips as it is all plastic and therefore doesn't corrode. Looks very professional when fitted.
http://www.ebay.co.uk/itm/Car-Door-Guard-E...27cac56ea1
ndf's plastic strips don't seem to go out of shape like the original ones.
Thanks Thumbs Up
Post #354507 28th Oct 2015 7:02pm
SMUTT
United Kingdom 2002 Range Rover Vogue 4.4 V8 Oslo Blue
^--- +1 for @NiceDayForIt solution
Fitted the same to mine last year. Perfect. Very Happy Howard
____________________________________________________
2002 4.4 V8 LPG Tartarini
Have RSW AllComms in Cheshire J17 M6 - happy to help.
*Gone: Classic Vogue SE Auto V8 3.9 Sad
Post #354515 28th Oct 2015 7:48pm
mjdronfield
I’ve just ordered some of the plastic door edge ones. The Land Rover ones have all corroded and bent out of shape.....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #599856 6th Jul 2021 9:45pm
