![]() | Home > Off Topic > Sun No Show |
Bought two of those solar panel trickle chargers one for the MH and one for the wee car that gets towed behind it , although not a great deal of sun , still says they would work during daylight hours ......
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 ![]() ![]() ![]() |
So.....for a pre 2010 - in the boot or in the cubby box.....neither much use for a solar panel |
@stevegt
stevegt Member Since: 17 Apr 2010 Location: Worcestershire Posts: 255 ![]() ![]() ![]() |
From memory the Arapaho is based on a Fiat Ducato chassis. I don't think that Fiat use permanent live cigarette lighters but I may be wrong. To check easily see if you mobile phone charger will work with the ignition turned off.
Cheers for the reply , better check the wheelie bin .............. |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
How about an aerogen? These are the small wind turbines many boat-owners mount on a handrail to keep the boats engine and house batteries charging during the week when they are not using their boat. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
Think a Match would be better .......... |
pjb Member Since: 15 Feb 2010 Location: Sunny Oxon Posts: 244 ![]() ![]() |
Hi Mick,
Cheers pjb will give that a go once it stops peeing from the heavens ....... |
Aerogen makes all sorts of kit from nebulisers through to solar panels so trying to find their own website isn't easy but here is a link to some of their marine turbines http://www.shop.solar-wind.co.uk/acatalog/...rogen.html
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3805 ![]() ![]() |
Mick, no solar trickle charger is going to keep up with a battery discharge over two days - unless its a solar panel the size of a house. You either have knackered batteries or a huge drain on them.
