Home > In Car Electronics (L322) > Fuses td6
Page 3 of 4 <1234>
Post #356880 14th Nov 2015 2:31pm
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
Well its pouring down here so in my wisdom i shut my self in the rear luggage space, and well im blowed its comimg in like a stream. Big Cry
Post #356881 14th Nov 2015 2:40pm
There's a rubber bung in the bottom of the compartment where all the modules sit, you can remove it to let the water out again. Thumbs Up Very Happy
Be worth checking the spare wheel recess as well. Thumbs Up
Post #356893 14th Nov 2015 3:40pm
brian1951
Amazingly spare wheel well is dry, possibly the last couple of days weather has done the damage. Any links to a new seal or is it LR only item.
Post #356894 14th Nov 2015 3:45pm
The seal is LR only, best place to get is via Dan@Duckworths, forum sponsor. Just send him pm with your requirements.
Post #356898 14th Nov 2015 4:01pm
brian1951
Had a good look today and it turns out the tailgate seal is OK, water has been getting in thru the side trim so i have removed it fitted new clips and sealed it, all seems to be ok now after 20 mins of hose pipe abuse. Thumbs Up
Post #357263 16th Nov 2015 4:40pm
brian1951
Latest update, Being a stubborn old sod i thought i would have another go at it today. I stripped the tv/entertainment unit and solder two wires to the PCB, then connected them to the loom the other side of the blue connector. And hey presto we have a monitor again. Next job is the radio, got it working but only for 5 mins ( switch it off and then on it works for another 5 mins ) I will keep at it Bow down Big Cry
Post #359218 27th Nov 2015 4:55pm
brian1951
Apart from the three plug in connectors on the amp i noticed there is a aerial type connector should this have something connected to it ??
Post #362642 17th Dec 2015 6:57pm
brian1951
How do i establish if my amp is the problem OR the BM54 radio tuner to my no noise music system?? Help please Bow down
Post #362676 17th Dec 2015 9:33pm
Although there is an aerial connector on the DSP unit nothing is connected to it.
When your radio works, press menu on the screen buttons and go to "Systems menu", you should see DSP highlighted on the screen.
When your radio stops playing go to the same screen and see if DSP is highlighted as before.
I have a suspicion DSP won't be highlighted in which case your problem is with the DSP unit not the radio tuner.
Post #362728 18th Dec 2015 11:31am
brian1951
Cheers niceday for your reply. im going to attack it again today, no doubt more help will be needed Thumbs Up Thanks Brian.
Post #362730 18th Dec 2015 11:39am
brian1951
DSP is not coming up on screen, does anyone know to a amp for sale?
Post #362739 18th Dec 2015 12:28pm
Have you tried taking the casing off the DSP and looking for water damage on the rear of the sockets on the top.
It's worth a go. If you find any dubious connections onto the socket it may be possible to bye-pass the connection and take a cable outside the casing to connect onto the appropriate harness cable.
You could always do away with the DSP as per this,
http://www.fullfatrr.com/forum/topic30365....eplace+dsp
Post #362750 18th Dec 2015 1:57pm
brian1951
Yes i have had it apart and all seems good and clean inside no sign of water
Post #362751 18th Dec 2015 2:05pm
brian1951
http://www.fullfatrr.com/forum/topic30365....eplace+dsp I find that a little hard to follow
Post #362753 18th Dec 2015 2:12pm
Page 3 of 4 <1234>
