![]() | Home > Maintenance & Mods (L322) > BMW M62 4.4 engine on petrol and LPG Coolant pressue problem |
jakebullet64 Member Since: 28 May 2014 Location: Wolverhampton Posts: 259 ![]() ![]() ![]() |
Hi,
SMUTT Member Since: 30 Jun 2014 Location: Cheshire Posts: 459 ![]() ![]() ![]() |
Couple of points
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
A good tip also DONT over fill the expansion bottle!
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
This is the thread:
Many thanks for the replies chaps.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8713 ![]() ![]() ![]() |
I looked at fisha's thermostat and it's great if you want to keep it standard, but I could only find one that was three times the price of this which gives you the option to fit just about any temp stat you want, you do need to do a bit of metalwork to make it fit though....
trickymickey Member Since: 28 Mar 2014 Location: Worksop Posts: 46 ![]() ![]() ![]() |
Hi recently fitted the 80 c thermostat cap to my 4.4, still have the 200 coolant cap fitted , can anyone advise if they have had issues with the 140 cap. Been on other forums and owners seem to suggest problems with the140 cap, mainly leaks on the 4.4. Also any one have the part number, for this item. Also what does the 200 or 140 denote ? PSI, Llb sq inch, Kpa !. |
KPA, not PSI, if it was 200 PSI and it exploded I wouldnt want to be near it.
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1579 ![]() ![]() |
Mine had a 200kPa cap until a few days after I bought it and when it went in for a trans cooler replacement. The mechanic changed it to a 140kPa unit.
With many reports of radiator, hose and expansion tank failures there are no reports of the 140Kpa caps lifting and releasing excess pressure.
Not over sight, design choice to increase the running temp of the engine as a means to reduce emissions.... At the expense of spare capacity for overtemp/pressure. V8 or else ... |
I have had what I would call high pressure operation with my cooling system.
With the temps you have out there you really should get one of these with an 80deg stat... they run so much nicer at the lower temp, it really is a win win situation... the engine and all the ancillaries will last much longer... Everything under your bonnet was fine when it was new but after a few years they deteriorate quickly when you get excessive heat under there...
jaybear Member Since: 31 May 2011 Location: Marseille Posts: 156 ![]() ![]() |
May i just add that I just discarded the thermostat altogether 4 years ago( just kept the housing ) , after a i blowed a top rad hose .
