![]() | Home > Maintenance & Mods (L322) > BMW M62 4.4 engine on petrol and LPG Coolant pressue problem |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
Haylands, yes good suggestion.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8723 ![]() ![]() ![]() |
The only reason they made it run so hot (it never was run hot in BMW cars) was to pass the new (at the time) emission regulations, it was an old engine then and couldn't make the mark on part throttle tests, so they cranked up the heat to burn off more fuel, it worked and we got the best engine (at the time) that was ever put into a Range Rover...
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
quote.... Women tend to drive the RR Sport or Evoque round here.... unquote
OK,
That's what mine ran at before, with the 80deg stat it runs around 90deg with no viscous fan, I have electric fans that I've set to cut in at 99deg... they only come on if you sit in traffic for a while...
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1580 ![]() ![]() |
I'll have to find that setting. Do I need to use the IID tool for that? I did a run in to Sydney tonight. On the M4 the car ran at 99 deg C according to ScanGuage. In traffic on Parramatta Rd, it would rise to about 102-103 but drop back to 101 once I was moving. Back on the M4, it was back to 99. Outside temp was 30 deg C. I think I'll change thermostats. On my GEMS P38A, I fitted a cooler (82 deg C) thermostat into the inlet manifold and replaced the original thermostat housing with a fabricated empty "sputnik" I bought from Davis Performance landys. Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
Just push the right hand button on the message centre, hold it down until the display changes to nr.........
I shall go and look! |
Just tried it.
Sorry Ron, forgot to unlock first, once you have done this the menu stays open.
Thank you. Yes, I tried the checksum but it didn't work until reduced the number by 1 as you suggested. Unfortunately, the pixel problem makes reading the text difficult. I have a new ribbon cable but have yet to try fitting it.
