![]() | Home > Technical (L322) > Towbar electrics 7 pin to 13 pin |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
is this any help,
Pvw10 Member Since: 04 Nov 2015 Location: Ledbury Posts: 315 ![]() ![]() ![]() |
Some good info there thanks but doesn't answer it all sadly, I searched in just the 322 forums, will try wider searches next time. Many thanks
Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301 ![]() ![]() ![]() |
I changed mine from 7 pin to 13 following a fire on the socket. It's quite easy, plug and play loom, p obably the most difficult part was threading the new loom through the boot floor.
Cheers for that
Fleabay item eBay Item No. 131294496090 is the item yes ?
That looks like the harness. I can't find the link to the one I bought but will keep looking.
As our friends across the pond would rightly say, " totally awesome reply" I can't thank you enough, pictures so much easier than words.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
This is the kit that I used on mine, it's of a similar price, I can say that It's plug and play, and easy to fit |
That's the one for me then, quality counts big style, many thanks. Many thanks
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
I was a cheap skate and bought a new 13pin socket, and undid all the existing socket wires of the 2x 7 pin sockets and re-wired them into a 13pin socket. Seems to work so far!
Good plan
That's a Witter tow bar, which is after market, so there is a chance that you just have a bypass relay fitted and it's been programmed to the car, not sure what will happen if you plug genuine electrics in to that, hopefully it will recognise that you've come to your seances and just work without any fuss. Or if your really lucky you've got a cheap towbar with genuine electrics and all will be well |
