![]() | Home > Technical (L322) > Voltage readings. |
Bofa Bill Member Since: 04 Apr 2013 Location: Poole + Rugeley Posts: 174 ![]() ![]() ![]() |
Update
jj2908 Member Since: 12 Jan 2014 Location: UK Posts: 39 ![]() ![]() |
I had no such warnings but 1 difficult start followed by a no start. That was it - game over for the battery and the alternator.
AND the saga continues.
Car still stuck in low range and off the road.
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
I'm assuming you haven't changed the alternator yet?
Thanx Jock for that.
Yes, leave well alone until the alternator is sorted. Once done, do a battery reset and hopefully all your problems will be cured (no guarantees obviously).
Aye that seems like a plan.
Ian c2 Member Since: 19 May 2015 Location: Socal Posts: 217 ![]() ![]() ![]() |
I started getting similar symptoms (though not as bad) a couple of weeks ago .
Thanx for all the inputs
Lost for Words Member Since: 18 Jun 2015 Location: Warminster, Wiltshire Posts: 473 ![]() ![]() |
The ECUs require the correct voltage without fluctuation and electrical noise, thus a bad alternator can/will cause all sorts of issues to appear. On modern vehicles like this, even so much as a poor quality brake bulb can wreak havoc. If errors in communication occur, things like the transmission may go into failsafe mode to prevent possible damage, as the car can't be sure what's happening to it. |
Like I said , mine wasn't as bad as yours .
Aye mail order
Hey up folks
