Home > Technical (L322) > if anyone has the time can they offer advice?
vitola231
Canada 2007 Range Rover Supercharged 4.2 SC V8 Santorini Black
I bought a 2007 L322 supercharged in the summer, since i got it it had no low range nor any error messages etc when button pushed. I had other things to do to the vehicle (Hawke ceramic brakes, new rear callipers, new front bushes, oil and filters etc) I have to say, she’s a wonderful vehicle coming from three new mercedes in a row its nice to finally have a machine that just mostly works, or to say when it works it works Very Happy
Anyhow, brought it to a very nice independent specialist and they searched for codes, I will type exactly as they did.
Low range not operating.
code P0562-00 Found in transfer case module (system voltage to low). No codes in transmission control module, all terrain control module, and power train module.
Has anyone had this issue? The code being in this particular module does that mean say that module isn’t getting proper power or may it mean in general (battery, alternator, wires, grounds) I have on my list of to do’s to change the battery, doesn’t seem right size, then plugs are next . any advice would be very appreciated. thank you
Post #365799 7th Jan 2016 4:20am
fisha
Does the low range physically work as it should without errors appearing when you select it each time?
If so I wouldn't worry too much about it. Spurious errors can occur and get logged, but it may not necessarily be an ongoing issue. V8 or else ...
Post #365806 7th Jan 2016 8:27am
robbo770
Scotland 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Could just be as simple as a sezied transfer motor, not unknown if cycled to keep moving Thumbs Up Current vehicles
4.2 SC FFRR RSE 2010- facelift
Range Rover Evogue Dynamic Lux
Gone
Rejected RRS my14.5 nightmare
Disco B4 XXV convert
Freelander 06 SE
06 RFFRR 4.2 SC Vogue RSE
Audi A8 4.2Tdi Quattro (hated with a vengence!!)
54 FFRR 2005 model V8 4.4 Cobra Variant
53 Mitsubishi Shogun V6
Post #365810 7th Jan 2016 9:01am
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
Or if there is a fault perhaps someone disconnected the low range switch hence it doing nothing.
I looked at a TD6 many years ago which had just that! 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #365819 7th Jan 2016 10:12am
mpirie
Have you tried getting the codes cleared and the checking a day later to see if they have returned?
It may be an old code that's been fixed and never cleared from the ecu?
Mike
Post #365827 7th Jan 2016 11:01am
vitola231
Mpirie
Shoot, I don't know if they cleared or not Sad better give a ring. There was a new battery but dealer I bought from was questionable sort to say the least. Interior was mint, exterior mint and good price so bought anyway knowing it would have fake safety and some problems. Front end was looser than over cooked noodle. Still good buy, 112,000 km Smile. Will ring shop and dig here more for voltage test procedures.
Thanks for replies. To mention, it's completely dead, while pressing button there is no reaction at all, no light, no message. Vehicle has remarkable low end, feels like diesel unit so low range hasn't been priority but decided to get on it. Engage low range on wife's lr3 every couple weeks to keep it functioning, should really be doing this to mine also.
Post #365858 7th Jan 2016 2:44pm
