![]() | Home > Technical (L322) > 24 hours later with my first L322 |
steadyaway Member Since: 28 Feb 2015 Location: West Yorkshire Posts: 184 ![]() ![]() ![]() |
Looks smart. Enjoy. 👍 |
Eric Cartman Member Since: 05 Nov 2014 Location: Dublin Posts: 108 ![]() ![]() ![]() |
Also does anyone know how to change the dials to km/h ? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35817 ![]() ![]() |
its a setting in the menu..must be documented in the owners manual... ... - .- -.
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263 ![]() ![]() ![]() |
[quote=
Does yours throw any errors when it goes ? Nothing comes up on the dash for mine which is annoying to say the least, the bulb is a different colour to the right side so im going to check if its a cheap / old bulb first |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8769 ![]() ![]() ![]() |
The smart key batteries are easy to change
None at all! Turn on the lights, passenger side light off, turn switch on and off a couple of times, light comes on. These are both new xenon bulbs. I have a spare resistor which I'm going to swap when I get chance, but the screws are difficult to get at! |
Im not sure you can completely change the speedo to read Kmh, you can however get a little box in the centre of the speedo to read in Kmh:
Id find it very hard to believe the speedo can't be km/h , its a screen , I would have thought it would just be in settings but now I'm starting to think it may be a ccf edit or at worst a reflash. |
its probably a CCF edit, but its not something you can just do on the dash |
anyone know if an iidtool can change it ? I was probably going to get one anyway but If I need it for this it makes it more urgent. |
i think it can,
grand, anyone got any way of getting a discounted BT iid tool ? |
Lad Member Since: 12 Oct 2014 Location: Blackburn Posts: 284 ![]() ![]() ![]() |
The iid defo can change the dials the kph. Not just the little box but the numbers around the dial. There's plenty other reasons to buy one |
