Like nbunney said - they never come out intact - you might be lucky because your original set are quite new but I dont think they are supposed to be changed as often as you may change the wheel. The nut which secures the valve to the wheel is made of a very light cast alloy with a small seal which could get damaged.
I brought myself a second set of new alloys then needed to fit some TPMS sensors. The valve/sensors were reasonably expensive from Land Rover Parts for what they are I thought (approx £65 each)
I have seen a couple of sets available on the eBay in recent months, but quite rare (cheapest were approx £50 for the set) - however the lowest retail price I have found was from The TYRE EQUIPMENT COMPANY Ltd.
www.tyre-equipment.co.uk
They were the Genuine OEM Part (no.65741-67) which LR/Jaguar use themselves, manufactured by VDO/SCHRADER. I had to purchase a set myself a few months ago (£183.30 inclusive for 4) and they were delivered within 12 hours of ordering them.
Also - they are self programming, which means you will not need to have the Pressure Warning Light switched off by a dealer - they reset the light themselves within a few times of switching the ignition on/off.
