Home > Technical (L322) > Final Stage Resistor |
nar53 Member Since: 05 Nov 2015 Location: Le Mans Posts: 120 |
The Final Stage Resistor is playing up in my recently acquired 2002 TD6 L322. So I ordered a new Britpart one along with some other stuff & installed it yesterday. Tested it outside the house & all was well. a little while later I had to go for a short drive (about 20mins) About 10mins into the drive the fan blower went on full & no matter what I did it wouldn't turn off or slow down. Even when I turned the engine off it wouldn't stop blowing at full speed, So I pulled the fuse, left it to cool down & swapped the old unit back in. As this is a LHD RR access is very difficult (I didn't remove the Glove Box or Fuse Panel) Luckily I had left the Resistor hanging down where I could get to it & had not replaced any panels, which was good as it was dark at the time.
15th Jan 2016 11:41am |
Andy3681 Member Since: 13 Jan 2012 Location: Newcastle under lyme/ Le Dorat Haute Vienne Posts: 912 |
The resistor must be fitted into the airduct to keep in cool in operation. If you left it just dangling behind the dash it will overheat and burn out. The slower the speed the more current it is controling so will get hotter quickly.
21st Jan 2016 5:31pm |
Hmmm, Thanks for the input but not convinced. The original FSR still works but does weird things, the new one works too but only at full blast. I've got another new one coming on Monday hopefully that will sort it. |
23rd Jan 2016 1:08am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
Both dj and andy are absolutely spot on with there advice.
23rd Jan 2016 11:04am |
Full Fat Ray Member Since: 23 Jan 2014 Location: Cwm Llinau Posts: 574 |
The FSR is NOT 'simply a bank of resistors', neither does it vary the voltage between 2v and 8v.
25th Jan 2016 1:56pm |
^"Bank of resistors" might be a slight simplification but that is what it essentially does.
25th Jan 2016 2:09pm |
Stein Member Since: 16 Sep 2022 Location: Krokstadelva Posts: 4 |
Lot of important info in this thread. |
16th Sep 2022 6:50pm |
Any news on fan still not working after replacement of FSR? |
16th Sep 2022 6:53pm |
Sorry, but as a new member I need to post 3 times before I can send a PM to anyone on this thread with FSR problems… |
16th Sep 2022 6:55pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1516 |
I think the P38A pulse width modulation system was better. Ron B. VK2OTC
17th Sep 2022 10:02am |
Yes, bet you do. But do not help out on fan problem on L322… |
18th Sep 2022 1:04am |
peternicholls Member Since: 12 Mar 2022 Location: Stoke-on-Trent Posts: 36 |
I just fitted a new final stage resister. Now the fan speed dial only goes up to 6 and 7 won’t light up. What have I done? 😩 |
1st Jan 2023 9:41pm |
