Home > Technical (L322) > Left it unlocked last night...
Lookers Park Royal
HEVAC fan fault is the likely culprit!
Post #35035 5th Nov 2010 10:19pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
delamo wrote:
Thrasher wrote:
...Rear interior lights will turn off themselves......
Should they??? Why don't mine then??? - dammit, now mine has a problem Confused
Ahhh, BUT when you unlock the car, or open the door if its left unlocked the electronics all wake up again and your light comes back on.
It's playing with your head... seriously ... sit in and leave it on but don't touch owt for 15 minutes.
Thumbs Up 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #35036 5th Nov 2010 10:58pm
RRCanuck
Canada 2010 Range Rover Supercharged Supercharged Santorini Black
Almost elpeede Wink
Your right about unlocking it and all systems boot up but in my 05, if you only open the door when it has NOT been locked it only wakes up "slightly" and will go to sleep again after 2 or 3 mins. In my experience, unlocking the car but not immediately driving it keeps it awake for god knows how long and ultimately draining your batt.
@ Duke Thrust - here is an example: Get home from work and lock it up. Oh Censored , left my briefcase in the car Embarassed . Unlock it and all systems (including Nav Screen) power up. Grab my briefcase and then put my key in the ignition, turn it to 2nd position back again and key out. This shuts it down again. Thumbs Up Takes 2 seconds. If I don't do this, Nav screen stays on even after I have re-locked it.
Now, on the flip side, if I haven't locked it and need to go back to the car to get something, I do not have to go through this routine. This is my experience and I don't worry about my battery anymore.
mike.
Post #35042 6th Nov 2010 1:44am
Duke Thrust
Locked it last night, will see what it's like this morning...
Will also do some research on the HEVAC fan, is this the resistor module fault?
Post #35055 6th Nov 2010 11:58am
td6 vogue
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Seems i have the same problem. New battery a couple of weeks ago now car is completely dead. I always leave it in the garage unlocked.
Post #35133 7th Nov 2010 7:43pm
Emperor Mong
I once noticed that the nav screen was on in my car long after I'd locked it (prob 30 min or so). I opened and relocked it and it went off. Not sure how this helps but I think sometimes the car doesn't sleep.
Post #35142 7th Nov 2010 9:09pm
Duke Thrust
Okay, so locked each night, no problems since - will update in case of further problems.
Post #35354 9th Nov 2010 11:03am
