![]() | Home > Technical (L322) > FBH Guru - French Mike. |
Temp gauge problem is more likely a thermostat issue (either main thermostat or EGR thermostat).
JLS Member Since: 25 Jan 2016 Location: Oslo Posts: 23 ![]() ![]() |
Thx for quick response, Joe90! I will dive into the Rover 75 forum for a search for Mike |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3982 ![]() ![]() ![]() |
Have you considered the gauge may be reading correctly and the engine is being over-cooled.
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
This post has been edited by the site administration team: email address removed from public view |
Thx, PaulB. Iīve got in contact with him already. |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
As Joe90 advised have a look at the thermostats. On my TD6 I had the same issue, car never getting up to temp. On advise from this forum I took off the EGR thermostat which is easy enough and blew through it. It was stuck open so got a new one and problem solved. Even got a slight improvement on fuel consumption so should pay or itself in a couple of years. A tip, I picked up a very cheap EGR Thermostat for a BMW which had a different end for the hose connection, luckily the ends are interchangeable so was able to swap over
Thx, Wayneg. I bought the EGR-stat at a BMW-dealer and saw that the end was different after buying it... Nice to have confirmed that its possible to swap the ends. I havenīt had time to investigate this yet |
Cool I'll have a look at this when I replace my lower hose! Is it as simple as if you can blow through it at all then it's dying?
You pull the big C clip thing out to release the end, there is a big spring behind so be careful. A fair bit of pressure to get the replacement end to seat against the spring before you can replace the C Clip. The other thing is if you watch the Video he makes it look simple to remove the hose to get at the bolt at the back, Not quite the same on the TD6. If I did it again I would have a jubilee clamp ready and cut of the spring type clamp to keep things simple. Still very straight forward though.
