Home > Technical (L322) > Supercharged Tyre question ......... |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
hi mate and welcome..
8th Nov 2010 4:03pm |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 |
Are you sure on the tyre size? FFRR have 255/50R20 as standard. Edit: Scarey beat me to it. |
8th Nov 2010 4:06pm |
sharpm Member Since: 08 Nov 2010 Location: Central Scotland Posts: 33 |
yes correct 50 profile as standard and ive edited my original post !!
8th Nov 2010 4:38pm |
if still under warranty then could be best to stick with the tyre size thats on at the moment, but once out of warranty then you can do what you want... ... - .- -.
8th Nov 2010 4:48pm |
Would a wider tyre aquaplane easier in the wet?
8th Nov 2010 7:30pm |
depends if you have enough grooves in the tyre ..look at f1 cars with their very wide tyres.. ... - .- -.
8th Nov 2010 8:15pm |
... Hmm, so wide is good if I change them every time it rains? |
8th Nov 2010 8:19pm |
That was why i took the 275 x 45 x 20's off and left them in the garage in the wet the car was sliding about more than Wayne Rooneys bell end in a Kellogs Frostie ...... |
possibly down to the amount of tread and make of tyre you had mick...275 is only 2 cm wider than the standard 255 size and shouldn't make a difference..
8th Nov 2010 8:27pm |
any views on the best road tyre brand to go for ?? |
9th Nov 2010 12:12pm |
stick to a well known brand and you will be ok...as for recommendations, one persons view might be different to another's... ... - .- -.
9th Nov 2010 12:15pm |
Cheers Stan
9th Nov 2010 12:21pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3692 |
there is wide and there is too wide . LR fit 255 to the L322 for a reason, personally I'd stick with OEM tyre sizes if possible.
9th Nov 2010 12:43pm |
Should that not be 20cm stan ......... |
9th Nov 2010 12:50pm |
