Home > Technical (L322) > Tyre Pressure Monitors
Andpopse
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Can anyone tell me how I can tell if I have TPM. My FFRR is an 06 Vogue sc Supercharged. I assume this is a std feature, but need to confirm.
Thanks
Andy
Post #35492 9th Nov 2010 10:27pm
elpeede
England 2003 Range Rover Vogue Td6 Zambezi Silver
Devils spawn Evil or Very Mad more trouble than its worth. Finally got it disabled on the runabout (Laguna)
We now use the manual method... firm kick and rebound is ok... dull thud is low.... clunk and broken toe is Censored ed Laughing 2010 Disco XS TDV6, 2009 Freelander 2 GS
Previous Landrover products -1990 110 TDI CSW, 2003 TD6 Vogue - RRC TD Vogue, RRC v8 Fleetline, Disco ES V8 LPG, 101 Ambulance "Morph", 1964 SIIa Auto Powered by Jag 4.2 Lump - "Percy".
Post #35495 9th Nov 2010 10:39pm
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
You should have a light which comes on in the dash display when you first turn the ignition (bottom left corner, yellow - looks like a cross section of a tyre) - if it comes on with all the other lights then goes out after a couple of seconds once you have started the car - then you have and everything should be all ok - if the pressures are low on any particular tyre (including spare) the light will stay on and you will also get a message which tyre is low on pressure on the dash message display.
Post #35496 9th Nov 2010 10:41pm
Avi
2006 Range Rover Vogue Td6 Alveston Red
Never knew it did the spare as well ! Apologies if i've posted this on my phone and it contains strange spelling and punctuation.. i just can't be bothered to correct it Very Happy
Post #35499 9th Nov 2010 11:06pm
Stocky
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Fuji White
Don't forget though, if you have a slow leak it won't pick that up. Has to be a fairly quick reduction in pressure.
You'll still need to do the manual method now and again. Wink
Post #35502 9th Nov 2010 11:18pm
Avi
How do they work??. The one's on our Mini use the abs sensors to detect of one wheel is dragging more than the others, and it seems pretty good at detecting a small drop in pressure. I presumed that if it also monitors the spare it must use some other hocus pocus Very Happy Apologies if i've posted this on my phone and it contains strange spelling and punctuation.. i just can't be bothered to correct it Very Happy
Post #35504 9th Nov 2010 11:31pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Wireless transceivers in the valves .... Btw, it is NOT a standard feature. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #35508 9th Nov 2010 11:44pm
delamo
Each valve on the wheel is connected to a sensor of one kind or another which fits inside the wheel / tyre - it is all part of the same unit.
Within the proximity of each wheel is another sensor which picks up the signal from the sensor on the wheel and hey presto - thats how you know if you have a low pressure etc.
Sorry - i don't know the exact technical terms / details but its quite simple really.
Edit - yes (what Thrasher said - wireless trancievers etc.) Thumbs Up
Post #35509 9th Nov 2010 11:45pm
Avi
I thought it was standard after 2006 ? I have no idea if mine has it or not Very Happy Apologies if i've posted this on my phone and it contains strange spelling and punctuation.. i just can't be bothered to correct it Very Happy
Post #35511 9th Nov 2010 11:48pm
DMRR
If you have it, the MID unit will have a screen for it, and there is also a button/indicator on the centre console. It is not standard on any RR, it is a factory fit option. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #35512 9th Nov 2010 11:52pm
Paul J.
Erm ........
.... you could always let down one of the tyres and see whether anything crops up on the dash display Thumbs Up
Paul
(BTW I had to have all of mine replaced under warranty owing to corrosion of the valve stems. The replacement stems appeared to have a protective coating on them)
Post #35514 10th Nov 2010 12:01am
Avi
Hmmmm. I have no button, or screen. But i do have a little warning light that looks like a cross section of a tyre with a warning triangle in the middle. It comes on with the ignition for a few seconds. Apologies if i've posted this on my phone and it contains strange spelling and punctuation.. i just can't be bothered to correct it Very Happy
Post #35582 10th Nov 2010 3:29pm
