Home > Technical (L322) > Is there more than one type of heated windscreen?
Mistercorn
United Kingdom 2010 Range Rover Autobiography 4.4 V8 Java Black
I have a 2007 TDV8 with the heated screen. Due to some damage I have just had the screen changed, now the heating no longer works. On the new screen there is a two pin connector at each end as well as a 1 pin connector. The 2 pins are for the left and right parts of the screen, the single pin ones for the left and right halves. I have spoken to the installer and he insists that the old screen only had the one pin at each end, so the two pin connectors do not plug in anywhere. This makes it sound like the screens have changed at some point and I have the wrong one fitted.
Does anybody know if this is the case, or does anybody have access to the wiring diagram for a 2007 car that they can check the wiring diagram?
Thanks very much for any help.
MC
Post #373903 24th Feb 2016 1:15pm
Yes 02-05my has BMW plugs
05-09my has Ford/Jag plugs
09-12my has a different plug angain
There are also several types of screen for each model year sir so as a guess? There maybe 100 different screens made for the L322 RR through the 10/11yr production...
Post #373906 24th Feb 2016 1:40pm
Mistercorn
Thanks, it is making sense now. There are a pair of single pin connectors on each side on the A-pillar which are live when the heater is turned on, so these must be the feeds to the screen. The connection location must have changed as well as the connector type, it looks like an early screen has been fitted. To be fair to him the fitter is being very good, he has been back on to his suppliers and they are sorting out a new screen for early next week.
MC
Post #373910 24th Feb 2016 2:12pm
sleepezy
I had my windscreen replaced this weekend - 1st attempt they brought the wrong screen - it was for the right model and year but had a different clip for the rain sensor - there are loads of different ones, but not as bad as the Volvo ones though.
Post #373918 24th Feb 2016 3:31pm
Sandyt
Its not just the actual physical connections but there are different acoustic values too what I did was get the original code from Landrover and this is what I got so plenty of room for variants
Product Code: 7033AGAGNHMV6T - LANDROVER RANGE ROVER 5J 2002-ON WINDSCREEN-GREEN+ACOUSTIC+GREEN TOP TINT+HEATED+VIN+MOISTURE SENSOR+ROUND BOSS
Post #375653 4th Mar 2016 7:48am
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
Acoustic values??? What's all that about? Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #375756 4th Mar 2016 7:49pm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
were not all the screen the same austoic value?
Post #375770 4th Mar 2016 8:32pm
No... Mine has acoustic glass and it makes it a lot quieter than a like for like model without Whistle
Post #375804 5th Mar 2016 1:17am
Flashman
I think you cannot upgrade to acoustic glass if your original car did not have it originally installed. Tom
Current Drive
Previous Drives
Post #375815 5th Mar 2016 10:19am
steptoe
Don't forget there's also the solar reflective option. Mr. Green
Post #375831 5th Mar 2016 12:18pm
supershuttle
According to the Autoglass man all Range Rover screens from Pilkington have acoustic glass on account of the fact that most are diesels which obviously make more engine noise but that may be Censored
I have to say there are no symbols on the screen that show it, like there was on my LR screen, but it's quiet enough so it does me.Very Happy Geoff
Post #375868 5th Mar 2016 3:55pm
