Home > Technical (L322) > Help - Clunk when selecting reverse and other issues
babagee
United Kingdom 2009 Range Rover Vogue TDV8 Stornoway Grey
After 12 months of faultless performance my 2009 3.6 TDV8 has just pinged Big Cry
1) Clunk on selecting reverse
2) Display reading 'Transmission Fault - Traction Reduced'
3) ''Terrain Response System Faulty'
4) 'Parking Brake Inactive'
5) Power steering just gone heavy
6) Limited power
7) Charging warning light on
94,000 miles
Any ideas
Thanks
Ian
Post #374540 27th Feb 2016 5:06pm
Mcnallykev
Scotland 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
My first thought is the Battery but I suppose that would cause ether clunk in reverse!
Post #374549 27th Feb 2016 5:48pm
rar110
Has it happened once, regularly or every time? Does it happen in Drive and sports mode? Do the faults clear on start up? Has it had a transmission service? ______________________________
Post #374590 27th Feb 2016 9:53pm
Start with the battery light on part and work from there.
The rest could be power related, it sounds alternator or battery related to me. Check its charging properly and giving the right voltages when running etc. Plenty of info on here on tdv8 alternator woes. Much cheaper to start there than go panicking into a transmission problem. The 6hp26 is seeming to be fairly robust with few broken ones. There is nothing that can't be fixed with a hammer😜😜
Post #374602 27th Feb 2016 10:35pm
babagee
Thanks guys
Yes I am leaning towards something electrical
The faults are intermittent but re-occur after a couple of miles
System shirts down and reboots
Let's see what the auto sparky can find tomorrow
Ian
Post #374680 28th Feb 2016 2:36pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
A long shot, but I had the same symptoms after doing the thermostat housing.
Check the fuel rail sensor plug for a bad connection.
I had all the faults you mentioned bar clunking in reverse and the charge light on. Until I plugged in the IID tool, I could not suss it out.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #374718 28th Feb 2016 5:50pm
babagee
Update
New alternator fitted and the FF now running like a dream Very Happy
Thanks for your input
Post #375379 2nd Mar 2016 7:55pm
