Home > Technical (L322) > 03 oil filter vibration
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
hi folks 03 4.4 lpg runs well 19 mpg 12000 i am getting vibration from oil filter housing intermittently quite loud roar clears after a while i changed oil filter [mann] which stopped vibration for a while but it has came back any ideas?
Post #377749 16th Mar 2016 3:39pm
holidaychicken
Not sure if this is relevant or even if we have one but read this on meeknet M62 site.
Not sure what would give a roar or you may already be sorted
I only use OEM filters as only about £10
Post #378987 23rd Mar 2016 1:57am
rik
hi thanks for the reply. vibration def coming from filter housing its not doing it all the time and goes away.i use mann filters and i cant see why it would vibrate a bit annoying thanks again richard
Post #379335 25th Mar 2016 11:37am
holidaychicken
Have you checked the rubber mounts on the filter housing are not split as that is a very common problem?
Post #379340 25th Mar 2016 12:03pm
rik
hi why would it vibrate intermittently? filter housing seems pretty solid . quite bad at 2500 revs .
Post #379386 25th Mar 2016 7:17pm
holidaychicken
can you get somebody to rev it while you have your head under the bonnet and put your hand on it to dampen it or use an electronic stethoscope / ear to a screw driver ( the blunt end) ?
Like all vibration, it will resonate at a certain frequency band and occur due to a set of conditions causing it i guess.
Post #379393 25th Mar 2016 8:10pm
rik
oil filter def vibrating mounts seem ok. seems to start when turning steering left. had her out all day today no sign until we got home and left her an hour then started again really annoying the whole oil filter housing is rattling but is fixed solid
Post #379862 29th Mar 2016 12:54am
holidaychicken
And it stops the noise when you put your hand on the filter housing ?
Power steering pump maybe, mine makes more of a noise when its on full lock but doesn't vibrate anything noticeably?
Post #379873 29th Mar 2016 8:04am
ndg
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
The rubber socket at the bottom could be perished/gone. Worth a check.
Post #379882 29th Mar 2016 9:13am
rik
noise stays even with hand on filter will check rubber mount on bottom seems to only do it when accelerating but no noticeable change in performance
Post #380383 2nd Apr 2016 12:03am
holidaychicken
When you change the filter, is the filter clipped to the cap when you remove it?
Post #380401 2nd Apr 2016 8:09am
rik
will have a look. i have ordered new mounts and will change when they com. i was thinking along the same lines that the filter is turning in housing but i think that would be hard as the filter went in pretty tight
Post #380405 2nd Apr 2016 9:36am
holidaychicken
I think there is supposed to be a valve in the bottom of the filter housing that the filter pushes closed and when the filter comes out attached to the lid it opens the valve so you could check the condition of the valve. It also stops the drain back from the housing when engine is off.
On a BMW site they show the filter being attached to the lid before fitting but I think I read in the Land Rover manual that the filter is pushed into the housing first.
Not sure if anything I just typed gas any relevance to your problem Confused
Post #380422 2nd Apr 2016 1:16pm
rik
checked top housing today .both housing bolts have no rubber on them at all. just steel tubes linking bracket to filter / there is no evidence of rubber ever being there/ i know it would make sense to have rubber mounts. there is one on the bottom of filter/ had her out today 40 miles no noise at all running like a dream cant make sense of it has anyone else seen mounts that have no rubber on them or has mine been modified ? i have had her 3 years now and have been under bonnet lots of times/ never noticed rubber mounts on oil filter/ how would you check valve? filter fits tight to bottom of housing and would be very hard to fit if mounted in lid first. as in impossible to turn without destroying filter. will fit rubber mounts when they come and post result
Post #380437 2nd Apr 2016 5:54pm
holidaychicken
Thats cool, they have obviously broken in the past and somebody has 'fixed' them as when the rubber goes there is nothing to hold the filter body in place. They usually get old and brittle and then the twisting motion of undoing the filter cap breaks them off.
Don't worry about the valve, it's there to allow the oil to drain out when you change the filter so if you haven't got oil when you change the filter it should be ok. sometimes they get stuck open and allow the oil to drain back so when you start you get the clatter but that is normally caused by the vanos or timing chain tensioner or non return valves behind the vanos solenoids but that is a whole new topic.
Glad you have sorted it
Post #380459 2nd Apr 2016 7:33pm
