Home > In Car Electronics (L322) > Satnav lost the plot
Ivor
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
As title says my satnav was working fine until today I went to the nav screen and put in a postcode which was fine then I set off on my journey and noticed the satnav wasn't following the road and by the time i had driven 6 miles it reckoned i was in the sea ,I tried recalibrating it and same thing happened again,it's okay when stationary but loses it when on the move
I have got a 2016 rusty disc in the system which has been fine
The rear speaker panel detached itself on the weekend but i can't see that affecting it L322 2008 vogue
R53 Cooper S Works tuned beyond the works SOLD
R33 Nissan Skyline in rebuild 400bhp atw
Post #377755 16th Mar 2016 4:23pm
have a look behind the speaker panel and see if there are any lose cables or plugs detached, other wise try a battery disconnection.. ... - .- -.
Post #377758 16th Mar 2016 4:32pm
There is something about this somewhere, something to do with the gps antenna in the shark fin as far as I can recall there can be water ingress and it can fail. Rolling Eyes
Try stans disconnect, see if it makes it better, Rusty discs are usually ok (probably not allowed to say that shhh) so unlikely that's the problem. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #377803 16th Mar 2016 8:08pm
33sport
2007 Range Rover Vogue TDV8 Stornoway Grey
I had the same with mine I changed the sharks fin and all is jolly again Very Happy . Do you have the GPS signal icon in the top left corner on the map screen?
Post #377813 16th Mar 2016 8:38pm
Ivor
well in the true range rover manner it's fixed itself and giving me more info than before it now tell me about roadworks ahead L322 2008 vogue
Post #377998 17th Mar 2016 3:49pm
NMJ might be correct in his assumption, its dry and sunny now so your nav is working ok, i bet the next time it rains you'll have problems... ... - .- -.
Post #378004 17th Mar 2016 4:20pm
Ivor
Yeah i know what your saying that was my first thought as well L322 2008 vogue
Post #378007 17th Mar 2016 4:33pm
Birdbrain
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Ditto. Mine was cracked. When the sun shone it worked. When it rained it didn't. Easy enough to fix and takes about 30-40 minutes.
Post #378021 17th Mar 2016 5:53pm
