Home > Technical (L322) > Transmission Problem
RR1234
2014 Range Rover Autobiography SDV8 Luxor
Driving home in my December 2003 RR Vogue (3Tdr) and it lost forward motion! On the motorway hard shoulder it would only drive in reverse. 141k miles with full service history and gear box oil & filter changed at 103k. Anyone any ideas what the problem is and likely cost to repair fearing the worst Sad
Post #375980 6th Mar 2016 3:42pm
Anywhere from low on oil, cheap fix, to new box, £1,500...
If it does need a new box then only use somewhere recommended there are a lot of rubbish places around...
Good luck... Thumbs Up Pete
Post #375991 6th Mar 2016 4:28pm
miggit
Shocked I recon that'll be a Big Cry job, and it will need a rebuild Sad Yesterday I couldn't spell Engineer... Today I are one!
Inventor of the 'Guide-o-Matic automatic wheel alignment tool'
Former long term L322 owner, Up/Down graded to a Classic Tractor!
Post #376003 6th Mar 2016 5:31pm
lighthouse
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Santorini Black
i have to agree i'm afraid sounds like its a rebuild or a new box, expensive either way.
Good luck and let us know how you get on.
Post #376006 6th Mar 2016 5:43pm
RR1234
I will hopefully know by COB tomorrow what the problem & proposed solution is when I will post an update. I just spent £300 having a squib replaced as the Airbag light was staying on and it would have failed the pending MOT.
Post #376020 6th Mar 2016 6:33pm
RR1234
UPDATE
Car started and both drove into and reversed etc at the garage. Various diagnostics and tests presently being carried out but I think it might be another electronics/ sensor issue. Recently my steering airbag sensor squib had to be replaced and the parking sensors are a bit chaotic. Over the past while other electrical bits and pieces having been either failing or playing up.
When I know the final our come I'll let you know.
Post #376365 8th Mar 2016 3:41pm
Sorry to be negative sir... But they normally will drive again when they are cold for about 200-300 meters... Neutral
Post #376368 8th Mar 2016 3:43pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
As ctc's reply, mine was slipping really bad, but after a while waiting for b/down truck it drove on no problem.
At the transmission specialist, they couldn't replicate what I said had happened.
told them to strip it down anyway.
New tc, new clutch pack, new accumulater springs, and new valves, job was a good en, and been brilliant ever since.
£1400 +vat out of pocket, but well worth it. Thumbs Up
Post #376392 8th Mar 2016 6:17pm
RR1234
Transmission
UPDATE: I drove the RR to a gear box specialist and they confirmed the worst - gear box needs to be stripped & repaired @ £1,900 plus VAT! On the plus side I was able to drive the RR for about 100 miles before I left it with the garage. They said that gear boxes in my RR tend to go between 90k - 120k. I drove into the garage forecourt as the clock turned 141k. When I pick it up after Easter I'll provide a further update. Whatever happened to the days when hi spec vehicles could be relied upon to do 250k - 300k miles before they'd collapse - especially in an RR! Sad
Happy Easter motoring & thank you for sharing your experiences & thoughts.
Post #379138 24th Mar 2016 9:00am
One simple answer to your last question.... Profit.... Pete
Post #379149 24th Mar 2016 10:11am
miggit
Profit........ possibly...... Whistle Reckon that "I don't give a Censored , cos we've sold the company" came in to it Whistle Yesterday I couldn't spell Engineer... Today I are one!
Post #379165 24th Mar 2016 10:50am
Im sorry chaps but........... I don’t agree, that gearbox is used I’m many different cars and fails in all of them! NOT JLR’s fault and certainly not the poor old RR’s fault Rolling Eyes
Post #379171 24th Mar 2016 11:08am
miggit
But Why did they agree to a gearbox that's rated at 350 Nms max with an engine that produces 390 Nms, it just doesn't compute, especially when you look at the vehicle weight spec's for the box... I believe that the Range Rover is 0.6 tons too heavy... basically it's not fit for purpose.. if I had brought the car from new I reckon I'd be talking to a lawyer by now..
BMW knew that gearbox was flawed and ditched it very quickly.... just after they got shot of Land Rover Whistle
If someone was to come up with a viable solution to the problem, they would make a fortune... We know that you can get a 6 speed ZF to fit the engine, just need some bright spark to sort out the ECU issues and an output shaft that will work with L/R transfer box.
Having read rather a lot about the GM5L40E box this week, from what I can make out the biggest stumbling block is making a loom to run the gearbox.... surely you could ditch the factory loom and run another one along side... it's not like it's pushed for space under there, once you get passed the plastic covers there's enough room to get a football down the side of the engine....... Just needs someone to take the plunge, invest a bit of time and I reckon they'd be quids in Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #379287 25th Mar 2016 2:00am
RR1234
Transmission
Apparently the gearbox is actually a General Motors box which is fitted and delivered by BMW under licence? I will find out the the precise detail on that when I collect the RR.
To help cheer up the rest of my Easter break and raise a smile for the forthcoming brighter evenings and summer...what else can I expect to fail now that my RR is 12yrs old with 141k on the clock. I must add that the car is very clean and only had the toe bar fitted when I got it. Until then I think it was a Chelsea tractor Smile
Post #379348 25th Mar 2016 1:25pm
trickymickey
United Kingdom 2002 Range Rover HSE 4.4 V8 Adriatic Blue
I think you will find it was made under licence by Cadburys !
Post #379351 25th Mar 2016 2:13pm
