Home > Technical (L322) > Sat Nav on the move!
kil2508
Wales 2005 Range Rover Vogue Td6 Java Black
Hi all
Finally bought a Range rover - 2005 Vogue Facelift.
Just wondering is there a way to enable the sat nav on the move (had it my disco 3 and got use it)
Sorry if there is already a post, but tried the search and couldnt find any thing.
Cheers
Gav
Post #37559 21st Nov 2010 7:40pm
i believe there's a unit that plugs in the back of the nav screen, not cheap or easy to do ... ... - .- -.
Post #37649 21st Nov 2010 9:10pm
kil2508
cheers i was hopng there was a hack like the tv.
Post #37662 21st Nov 2010 9:30pm
JustinP
Hi,
Follow the instructions to enable TV on the move detailed here http://www.fullfatrr.com/forum/topic2243.html but enter code 1791 instead 753.
Sadly 1791 does not work on my 2006 (just been out to try) but it may work on your 2005MY
AFAIK, the latest NAV DVD will update the firmware, and then you can enable destination entry on the move, although that may require enabling by the main dealer. I cant confirm for certain is I've not bought a new nav disk yet, but others on here will be able to confirm for certain.
Cheers
Justin
Post #37667 21st Nov 2010 9:33pm
there is on the pre touch screens cos they use an ibus system but the touch screen's use a MOST fibre optic system which is hard to 'hack'... ... - .- -.
Post #37668 21st Nov 2010 9:34pm
stevegt
United Kingdom 2006 Range Rover Autobiography 4.4 V8 Cairns Blue
Yes it is dealer enabled with the latest nav disc firmware... cost 1 hrs labour! actual time spent working? approx 30 seconds to tick a box on IDS.... followed by about 10 mins of the computer rebooting the car! 06MY 4.4 V8 Autobiography Cairns Blue with Navy & Parchment Interior
Post #37705 21st Nov 2010 10:50pm
