Home > Technical (L322) > Interior lights, 2010 FFRR
Dale
Finland
Dear gents.
Does anyone know, if same sensor for external illuminate would be moderated to adjust interior lights to be mute during daylight conditions?
My 2007 Merc has that smart function. Would be great for battery life and so on.
Thanks.
Post #388637 25th May 2016 7:45pm
interior lights only come on when a door is open so i dont understand your reasoning to be able to dim them.. ... - .- -.
Post #388667 25th May 2016 10:05pm
Merc’s don’t use interior lights in daylight hours Stan... The OP is asking if RR can do the same thing...
The answer is NO SIR Whistle Thumbs Up
Post #388668 25th May 2016 10:09pm
Dale
Finland
Darn, thx anyway.
And for Stan, yes I do keep doors open while thumbling w/pillows and matresses. There is beemer style gadget controlling wake mode stuff, like courtesy lights and so on. E-series Stuttgardian do have a module restricting this while bright.
Should've studied applied sciencies in electricity. My bad. Worth of investigating, MHO.
Great car, though. 7000 mls since Easter and stacking.
Ah, one or two other interesting sweep for s/w stuff;
- would be great to have select mode from infotainment (satnav) to project driving guidance between dials, since area remains pitch black normally
- same for radio channels, push feed when requested, aid for eyes on the road kind of thang Wink
Should have studied programming also... Still, great car!
Post #388674 25th May 2016 10:24pm
mjdronfield
If you keep the interior light switch pressed in for 3 seconds they will be deactivated. You will have to repeat the procedure to get them to work again. Not exactly what you wanted but may help....
 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #388689 26th May 2016 6:19am
Dale
Finland
Thank you, this is good to know.
Post #388690 26th May 2016 7:05am
wealy
United Kingdom 2014 Range Rover Vogue SDV8 Luxor
Dale
The function you require withe the sat nav between the dials is now standard with the 405 model
The interior lamps are all led also so minute battery drain so having a daytime senor would be futile.
Post #388691 26th May 2016 7:30am
good tip Mark Thumbs Up ... - .- -.
Post #388692 26th May 2016 7:30am
Dale
Finland
Have to start saving, then.
Tnx again.
Post #388708 26th May 2016 8:38am
