Home > Technical (L322) > Upper Tailgate Replacement
Door941
United Kingdom 2006 Range Rover Vogue SE Td6 Causeway Grey
Hi Guys,
I have a new upper tailgate for my ff rr 06 vogue se and I'm wondering if anyone has had any experience or can point me to a tutorial on how to replace the whole upper tailgate.
The 2 wiring looms will cause the biggest problem I suspect.
Thanks in advance.
Post #389746 1st Jun 2016 8:32pm
found this via the search function, should help a bit,
http://www.fullfatrr.com/forum/topic33066....e+tailgate ... - .- -.
Post #389766 1st Jun 2016 10:07pm
Door941
Thanks for the reply, I seen this too and funnily enough the exact same situation. I will try and document my removal and replacement so I can share things learned with other members.
Post #389784 2nd Jun 2016 6:21am
ndg
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
I swapped ours over a couple of months ago. The biggest issue is the wiring as it's a single piece loom with the rest of the car.
The loom runs down the RHS of the tailgate underneath the glass, and is clipped under there too. I was shown how to remove by the guy I bought the tailgate off. there's a small gap between the glass and the frame, and you literally pull the wiring through this gap from bottom to top, breaking the clips as you go. It's tight and I damaged the insulation on a couple of wires, so inspect and repair.
I fed the new loom back in the same way, squashing everything as flat as possible and working each wire through. Not easy, but possible. You end up with no clips in there, but I used a fabric loom tape and haven't heard any rattles from that area so all good.
Post #389807 2nd Jun 2016 10:38am
Door941
Hi Guys,
Followed the advice from ndg and right on the money the hardest part being the wiring loom that runs down the right hand side of the tailgate. it was quite straight forward once all the trim was removed.
Thanks for the support and info. was raining so no photos.
Post #391067 10th Jun 2016 4:08pm
