![]() | Home > Maintenance & Mods (L322) > Rear window relay |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8817 ![]() ![]() ![]() |
I take it these are other faults you have... pretty sure they are on the BECM so maybe yours is toast...
STU TDV8 Member Since: 03 Apr 2016 Location: norfolk Posts: 65 ![]() ![]() ![]() |
Im not sure what's wrong , I had an issue with my air suspension which ended up to be a high resistance joint in the boot where the 3 earth's are behind the spare wheel . So fixed that then when to test drive it up the road and the steering was heavy and the rear two door's both had electric window issue's ? . Also the top tailgate doesn't open on the key or dash control etc ??.... |
In that case I'd check the earth under the carpet at the front, it will mean taking the passenger seat out and side trim and carpet...
This is the earth point, all the brown wires...
Thank's haylands you have been a great help ill do it in the next couple of day's !... |
If you want to test it before it goes back together, just lay the seat in place and plug it in, wouldn't drive far though...!!!
Tested the earth's tonight and there all good so guess it's the BECM ? .. |
There has been a spate of Body Processor Modules failing recently mine included , all around the same age as well . 2008 MY Supercharged
Anybody know if the TD6 BECM unit will work on the TDV8 2007 ?.. |
Give Dan a ring, or send him a message he'll be able to tell... |
