![]() | Home > Technical (L322) > Whirring noise from engine bay |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35808 ![]() ![]() |
i wouldnt worry, theres always weird sounds coming from there...... ... - .- -.
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
Could be the cabin heater aux water pump. This is supposed to do that, and is a great help bleeding the V8 petrol engines. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8755 ![]() ![]() ![]() |
If it's all the time it could be the cooling fan for the ecu box, the big black one, it has a cooling fan in the bottom and a temp sensor, cools the ecu's when it gets hot... The fan's are known to dry up and squeak a bit, if you take the lid off it would confirm it... gave mine a blast of penetrating fluid and it's shut up since.... Pete
cheezels Member Since: 23 Apr 2016 Location: Sunshine Coast Posts: 279 ![]() ![]() ![]() |
Ok will check that. Cheers for that.
