![]() | Home > Maintenance & Mods (L322) > Strange issues... |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8814 ![]() ![]() ![]() |
Holding the gears is a cooling strategy, and also a hill strategy, it will hold gears both up and down hills if it thinks it will help, sometimes it's a pain, sometimes it helps...
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2261 ![]() ![]() ![]() |
http://www.youtube.com/watch?v=moECn9xjuy
espaceboy Member Since: 02 Aug 2014 Location: Fae Fife Posts: 86 ![]() ![]() ![]() |
are your brake shield loose |
What's the best way to tell with no tools( I have tools at home obviously) turn the wheels and shake the shield if they are accessible? Sorry for silly questions new to this 4x4 business |
the brake shields sit behind the brake disks and are thin metal and circular. If they are loose the can rub again the bake disks as they rotate and cause a chuff chuff sound
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 560 ![]() ![]() |
If the noise is coming from a rear wheel its possible a handbrake shoe has dislodged from the backing plate in the hub and is rubbing on the hub - had this before and it made a similar chuffing noise Current Fleet:-
yup, had that too now that I remember, good call |
&feature=youtu.be
Side note - this forum has been brilliant so far as good as if not better than the M5board which surprised me - so thanks guys |
Stuart Member Since: 06 Feb 2011 Location: Cambridge Posts: 85 ![]() ![]() ![]() |
Dan - had both front heat shields come loose on my 54 reg - one of them just as I got to the dealer's to ask for a part ex price!
Hi Stuart do the videos indicate that's the problem? I bent them a bit and the noise has gone so I can get home so I think it is or a stone was trapped I imagine |
My heat shields had rusted through in the area surrounding all three (or four?) bolt heads, so mine were rattling and clanging all the time the wheel was turning.
Fretless Member Since: 16 Sep 2015 Location: Renfrewshire Posts: 162 ![]() ![]() ![]() |
Maybe also check the heat shielding above the exhaust rear box - could be flapping around in the breeze. Long shot, but you never know... The best 4.4 x far |
