Home > Technical (L322) > Help - loads of warnings
Blackbird51
Hi all
Shortly after leaving home this morning the instrument cluster lit up and car went on to safe mode. Carried on until I had somewhere to pull over. Faults showing included - gearbox, suspension, abs, ebd, charging system, adaptive lighting, cruise control. Car would lock and unlock but boot would not open.
Using IID tool cleared all faults and then started car - no weird noises (thankfully). Following faults showed up on IID tool;
U2101-00(2F) Control module configuration incompatible
U2300-64(2F) Central configuration - Algorithm based failure - signal plausibility failure.
Got car home and checked battery, alternator and auxiliary belt - no issues.
Car would then not start.
Changed battery and car started. All looked well until I tried a test run. Can manage 500yds and then all then warnings come on again.
Reset clears all with exception of those above.
Firstly - where is the BCU located on 2010 model TDv8 - its not under the seats
Secondly - any help with how resolve issue would be greatly appreciated.
Thanks NM
Post #396631 18th Jul 2016 6:24pm
GraemeS
Australia
The symptoms suggest low voltage so likely a failed alternator/generator.
Post #396647 18th Jul 2016 8:08pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
What he said above. Check the voltage at the battery with the engine running, anything less than 13.5V is likely to be an issue with the alternator.
Post #396664 18th Jul 2016 8:38pm
wealy
United Kingdom 2014 Range Rover Vogue SDV8 Luxor
Bet your car has done about 80,000 miles!
Post #396684 18th Jul 2016 10:43pm
Blackbird51
Fully recharged the battery. Showing 13+ on voltmeter. Went for test run. All warnings back on. Got back to house stopped engine and checked voltage - now 11.0v. Wont restart. Back on charger.
95,000 miles
Post #396686 18th Jul 2016 11:50pm
wealy
What is the voltage at 1100 rpm?
It should be around 14.4 V
Post #396695 19th Jul 2016 8:21am
Blackbird51
Left car with local independent. It appears it's not the alternator. Common fault on list is failure to communicate with abs ecu. He has checked it but no faults show up.
Only puzzle at present is that when faults appear there is only a 3v supply showing at the secondary fuse/relay board in engine bay.
He is currently checking wiring and connections.
Post #397804 26th Jul 2016 5:04pm
Blackbird51
Problem solved
Hi all
Got car back this afternoon. It was a faulty/loose fuse link located in the junction box behind the battery.
Mechanic reckoned that the car had had the fault from new as the mounting bolts had been cross threaded and therefore the terminals were not properly secured. He said that the fault could have occurred at any time and could have appeared to cure itself depending on the contact afforded.
Alternator checks out OK and all fault codes are cleared.
Post #397979 27th Jul 2016 10:04pm
Always good when it's nothing major Thumbs Up
Post #398001 28th Jul 2016 9:31am
Baltic Blue
Sounds like you have found a good local independent garage.
Post #398002 28th Jul 2016 9:38am
Blackbird51
Yep. He trained and worked for local main dealer prior to setting up on his own. He only deals with Land Rover - mainly Discos and Sports - apparently they give the most problems.
And I though Full Fats were full of interesting features Laughing
Post #398022 28th Jul 2016 11:14am
