![]() | Home > Technical (L322) > Engine Over Revving at Idle |
unsolicited Member Since: 30 May 2016 Location: Bucks Posts: 130 ![]() ![]() ![]() |
Can be normal. The ECU raises the idle speed to allow the fan to work properly (that is if you have a model with the engine driven viscous fan). This cools the aircon condenser. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35806 ![]() ![]() |
can you fill in your car profile so we know what you have. ... - .- -.
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
If my 04 4.4 has been sitting somewhere with the doors open or not locked the battery level drops and the car will automatically raise the idle until the battery has regained a decent charge, normally after a bit of a run. It's normally after it's been to the garage and left sitting around while they work on it.
Brightondefender Member Since: 29 Jan 2013 Location: East Sussex Posts: 36 ![]() |
Thanks for all the replies. I have also updated what car I have in my profile |
Cool, thanks for updating the thread, nothing worse than following somebodies thread through and then no answer at the end |
