![]() | Home > Duckworth Parts > Costings gearbox service parts |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 ![]() ![]() |
Hi Steve,
lawsey Member Since: 28 Sep 2015 Location: newcastle upon tyne Posts: 65 ![]() ![]() ![]() |
Dan
Kit comprises of pan assembly, transmission fluid, screws, sleeve & plugs.
Does anyone know if I'll need the gearbox reset after unplugging the mechatronic connection? I need to put a new sleeve in when I do the oil and filter |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8800 ![]() ![]() ![]() |
I wouldn't, it'll sort itself out if it needs to, resetting can upset the poor little things..... |
Parts have arrived £180 incl vat & carriage. ZF 6 x 6 Ltrs Pan, Bolts & sleeve genuine ZF parts.
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
You need to run through the shift stopping at each gear a few seconds, this fill the valves that may have drained down. Then with the engine up to temp do it again and with engine running top up, remember it will be hot down there and burnt hair on the exhaust don't smell too good, don't ask! |
