![]() | Home > General > What is the difference? |
| Spelunker Member Since: 02 May 2016 Location: Nottinghamshire Posts: 248
Please forgive the ignorance, but what exactly is the difference between 4x4 and all wheel drive? QUID FACIUM TIBI
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8136
The end result is the same -
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8001
As Alistair stated, The first 4 in 4x4 means 4 wheels and the second indicates that 4 are driven, so you can have all sorts of permutations, especially on bigger stuff where you can have a 6x4 if it's got 3 axles and only 2 are driven. Or a 6x6 or an 8x8 etc.
| p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1587
Another difference is that AWD generally means constant 4WD like all Rangies since 1970 (and all LR since the early Eighties).
| rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119
AWD normally doesn't have a locking centre diff or low range. They would have some kind of torsion bias centre diff.
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
FWD in the UK means FRONT wheel drive....!!! Pete
My previous car, a Frontera had a button to select 'four on the fly' - meant that at low speed you could select between 2 and four wheel drive. Nothing special, but it meant that you could get an immediate feel for the difference as you were driving, flick it into fwd and you literally felt you were driving on rails. QUID FACIUM TIBI
| cliff5.0sc Member Since: 29 Dec 2015 Location: USA Posts: 137 |
The difference describes the action of the differentials. An all wheel drive car has 3 open differentials (save for some that have LSD on rear). A 4WD car can lock the center differential. What that means in practical terms is that an AWD car will "slip" and send all the power to the wheel that has the lowest friction. So if your front end or rear end is on ice or a theoretical mew of 0 then an AWD car will not go anywhere and a 4WD will continue to move.
| PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263
Along similar lines, can someone explain what a 'Crossover' is? |
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. Posts: 4029
Sometimes called a "Soft-Roader" a crossover aims to cross the boundaries between a traditional 4x4 and a car. Older 4x4 vehicles were sometimes thought of as being cumbersome as a daily drive, especially for those who don't really need 4WD all the time and the assocaited size which tended to come with stuff like Range Rovers, Shoguns, Landcruisers etc.
So I suppose you could say that the Jensen Interceptor FF was an early 'Crossover' car then! |
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035
'4x4' meaning for blonde women.
| RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932
Some vehicles with part time 4x4 will not have the differentials required for on road driving. You drive in 4x2 mode ON road, then switch into 4x4 mode only on low traction surfaces (off road or snow) when wheel slip can occur.
Hardly I had an early Interceptor back in the 80's. I would describe it more like a Gentlemen's Club on wheels. A bijou Gentlemen's Club at that |
| All times are GMT |
