Home > Technical (L322) > CAN ANYBODY HELP
Skip720
England 2002 Range Rover HSE 4.4 V8 Oslo Blue
CAN ANYBODY HELP
I have a 02 L322 range pig and have just got a trans fail safe prog message and also trans overheat message. Driving symptoms are when you go from P to D there is a violent jets and then there is drive but the trans prog failsafe message comes on. The car still drives but with limited power. I had the gearbox flushed by quattro care 12 weeks ago. My mechanic , who is a Land Rover specialist said the gearbox oil was black and didn't smell right. He changed oil and filter but problem is still there. He has suggested taking it to a gearbox specialist Any recommendations. I live in Wakefield West Yorkshire.
Cheers in advance.
Post #402591 30th Aug 2016 3:04pm
CS
See RRPhil new venture under "Other site sponsors"? Only Range Rovers since 1988
Post #402608 30th Aug 2016 4:13pm
Blaming the FF and calling it a pig for someone's lack of servicing is a bit harsh...
You should also have the main engine radiator, the gearbox oil cooler and it's supply lines checked for blockages as this can ruin a box in short order, lots of info if you use the search facility... You will need a new Torque convertor as well
There are an awful lot of dodgy gearbox "specialists" out there, if I were you I'd get a box from rrphil on here, he is a site sponsor and just rebuilds the 5HP24 box, he doesn't fit them but your independent should be able to do that no bother... Thumbs Up Pete
Post #402610 30th Aug 2016 4:18pm
Skip720
Pete you probably have a point . I have sent a pm to RRPhil and am awaiting a response. Thank you both for your advice, hopefully be back on the road again soon. !!!!
Post #402636 30th Aug 2016 6:21pm
