![]() | Home > Maintenance & Mods (L322) > Rear light cluster water ingress |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826
Remove light, take all the bulbs etc out then in the airing cupboard until it's dry, don't take it out the airing cupboard if it's real cold outside or condensation will fog it up again... |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885
i'd leave the hole you've drilled un-pluged so the light unit can 'breathe'. ... - .- -.
| Big Boy R44ROV Member Since: 14 Nov 2011 Location: Chadderton, Oldham Posts: 556
I'm with Pete on this. I did the same. I also used superglue round the edges of the light unit to re stick it, and then when that had dried, used clear silicon over the top very thinly to ensure no more water ingress. Totally invisible repair. Its been jet washed loads since and not a drop inside the light.
| Duracell777 Member Since: 07 Sep 2015 Location: Warwickshire Posts: 128
Same problem with mine. 3mm hole drilled in the bottom of each and not had a problem since. ( took couple of days to clear)
| GaryPFC Member Since: 08 Sep 2016 Location: Aberdeen Posts: 3
Thanks guys seems sensible to leave it inpluged, I will also leave in a warm spot overnight to dry out once opened. Will report result |
| Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591
If you can find a warm spot in Aberdeen you dont have to worry about lights |
| All times are GMT |
