![]() | Home > Technical (L322) > Zf trans fail safe - runs fine up to 10 miles |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Have a search around, could it be a problem with the gearbox overheating?
Gavc Member Since: 11 Sep 2016 Location: Croydon Posts: 3 ![]() ![]() |
The only time I get an overheat message is if I'm to heavy footed with it when it goes into fail safe and stays in 4th gear.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1014 ![]() ![]() |
That does sound like the usual 5HP24 issue : http://www.fullfatrr.com/forum/post115201.html#115201
Hi Phil,
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8722 ![]() ![]() ![]() |
Your best bet is to get the box removed and sent off to RRPhil, look here
Maybe use this as a benchmark (£1650 including fluid and a re-manufactured torque converter) and do some ringing around to compare prices : http://www.fullfatrr.com/forum/topic38677.html Phil |
Phil won't tell you, he is too polite...
