Home > In Car Electronics (L322) > Android stereo faults
mattyp
I have this Android stereo and there is a few problems with it.
1. wifi wont turn on from the menu. I have taken the unit out and the aerial is connected.
2. when you plug a ipod into it. It will only display the name of the ipod and no music.
3. when you get a incoming call it only displays the number and not the name.
4. I would like to change the colour of the display to green.
5. also where have people mounted the mic for the hands fee?
anyone else have these problems?
Post #406266 25th Sep 2016 9:19am
Zulu 10
As a security feature, in some systems Wi-Fi is inhibited (other than as a hotspot) if there is a 3G/4G broadband connection. Could this be the reason?
How are you connecting the iPod? Presumably through a USB connection. When I asked at Erisin they said that the head unit does not support iPod, so I suspect that the only way to get music in through USB would be using a third party generic app.
I have connected my iPod through a dock direct to the DSP.
Have you sync'd the contact list between phone and head unit?
I presume by this you mean the backlighting of all the buttons around the display? If so, Home>Settings>Elements enables you to tune the RGB backlighting to suit your car.
At the top of the O/S A pillar where it meets the head-lining.
HTH
Post #406304 25th Sep 2016 12:35pm
mattyp
Taken the aerial out and it's connected, iPod is a lead in the glove box with the iPod adaptor on it, phone book has been synchronised and I have looked in the menu and there is no way I can change the colour display. The microphone is mounted in the same position as you are one and when I receive a call is very hard for them to hear my voice
Post #411298 29th Oct 2016 7:09pm
Colour of buttons is under "element" in the settings... If that's not there it's under factory settings, code to get in there is 126
Internal mic is useless, run an exterior one up to the top of the driver's A pillar..
It will only work with very old iPods IIRC, stick all your music on a 32GB micro SD card and plug that in the unit...
None of them show names when you get a call from the oldest ones I've fitted upto 5.2.... even with the phone book uploaded... rather daft but no massive issue...
Can't help with wifi, try a reset... or do like I suggested on the other thread... Thumbs Up Pete
-Click here for Thread-
Post #411307 29th Oct 2016 7:21pm
