Home > Technical (L322) > Strange noise on my 4.4
mattyp
I started up my 2003 4.4 v8 this morning and it started making this noise in the video. Anyone else had this ?
Post #406379 25th Sep 2016 9:07pm
Dolphinboy
Not certain but could be chains going (guides or the tensioner?) shot in the dark but worth checking?
Post #406403 25th Sep 2016 10:58pm
RR P38
Australia 2003 Range Rover Vogue 4.4 V8 Java Black
When was the last oil change?
What are you using?
Manifold leak...........you want to hope.
Chain guide (s)? drop the sump take a look?
Post #406404 25th Sep 2016 11:24pm
holidaychicken
That's not a good sound from one of these, I started my timing chain guide preventative maintenance today to prevent them failing.
As already stated, the plastic timing chain guides fail and drop plastic bits into the sump.
I had a scare when my water pump failed which can make a similar noise, I used an electronic stethoscope to diagnose but you can drop off the drive belt and see if the noise stops but note how it goes on and you may need to remove the fan using the appropriate tools. You could try the old trick of putting a screwdriver tip on it and the handle up to your ear to see if the noise is coming from the water pump but don't chop your face off in the fan
Could be timing chain tensioner but I've not heard of them failing like that.
Sounds too harsh for tappets
I would be careful running it if it is the guides as if it drops a tooth it's game over
Post #406410 26th Sep 2016 12:39am
Clivefog
You can stop the viscous fan from turning.
Post #406421 26th Sep 2016 7:19am
holidaychicken
Having listened to my noise and yours, mine on idle is a lot faster but not entirely sure what that tells you, maybe because the water pump is geared by the pulleys making it turn faster, yours is in time with the revs.
This was my noise
And the cause
Post #406422 26th Sep 2016 7:26am
mattyp
Thanks for the comments, I have looked through the history with the car and there is no sign of a water pump change. I had the car serviced last month and they removed the sump because it was leaking and there wasn't any plastic parts in there. I will remove the sump and have a look
Post #406423 26th Sep 2016 7:35am
RR P38
Check water pump first.
Great set of videos there to go on.
Im pretty certain rubbish oil accelerates the guide wear, good quality engine oil is a must.
Post #406434 26th Sep 2016 8:55am
holidaychicken
i think the high temperature that the engine is forced to run at doesn't help the plastic guides either hence the 80 deg mod is going in mine this week also.
Post #406436 26th Sep 2016 9:03am
RR P38
Absolutely, I did mine a few months ago, all I see is positives so far.
Post #406437 26th Sep 2016 9:08am
mattyp
got in from work and the rr is leaking coolant from the front of engine. There is a small puddle
Post #406541 26th Sep 2016 7:49pm
Hmm, thinking the water pump idea might be along the right track.sounds like the shaft seals have gone and what you can hear is the bearings not liking being wet.... There is nothing that can't be fixed with a hammer😜😜
Post #406542 26th Sep 2016 8:02pm
holidaychicken
That could be very good news, mime wasn't leaking but it probably only a matter of time. make sure if it is you get a hella or Behr if you can as the cheap ones are useless i am told
Post #406547 26th Sep 2016 8:18pm
Dolphinboy
+1 for holidaychicken's advice
Get a hella (or Behr) - Def don't get a first line. They are sh@te.
Post #406563 26th Sep 2016 10:28pm
mattyp
Right sump is off and look what is inside
Post #406737 28th Sep 2016 7:50am
