![]() | Home > Maintenance & Mods (L322) > RestorFX |
| Markjohns1 Member Since: 17 Jan 2016 Location: Cheadle hulme Posts: 139
Hi getting a few scuffs an scratches sorted at a local body shop including tail gate and rear wheel arches. Car being java black quite a few blemishes swirl marks and scratches around the car and the chap suggested that he could remove all of these whilst sorting out the body work.He wants to use a correction system called restore FX.Anyone any experience of this product ?All comments apptecistef been told car will look like new.Wants £400 for applying this product. My concerns are will it last,does it work,can i still apply wax ,polishers and sealants agfterwards,does it effect the car paint work in any way? Full fat 4.2 Sc
| builder1966 Member Since: 23 Aug 2016 Location: ashingdon Posts: 299
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
Sounds a bit expensive to me, there are no products they can put on the paintwork to make it stronger and shrug off scratches or swirl marks....
| Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2723
Buy a machine polisher plus the kit for way less. It's one of the simplest and most satisfying jobs you can do. |
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. Posts: 4029
Like Mr Tee says, DIY. Anything someone puts on the paint will only ever mask the damage. If you want it gone for good you need to machine polish the pain.
You do know they have a speed switch.... This took about 2 hours including flatting, I didn't do the roof or boot though... BEFORE Flatted the whole car down with 2500 wet and dry.... Then out with the polisher, some G3, a wash and some Meguiars.... [URL=]
[/URL] Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- |
Makita 9237CB.
| jonnyboy54321 Member Since: 29 Jan 2016 Location: surrey Posts: 380
Nice work there chap. 2007 Vogue TDV8 with 255/55/20's fitted |
| alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801
Great! Thanks |
| kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492
You should start off with something like meguiars ultimate compound to see if at gets rid of the swirls etc and if not work your way to a more agelessive cutting compound like farecla g10 or G3 so you don't do any damage that does need a pro to remove! Also perhaps a dual action polisher rather than a straight buffer as there is more room for error that way!! Once you get it to where you want it then a good quality polish and wax will protect it and make it shine.
Mostly what mzplcg said, although I just used what I had in, 2,500 wet and dry, wet... stay well away from panel edges and swage lines then I had some Farecla G3 rubbing compound, then "T" cut and finally Meguiars fine polishing compound and finally Meguiars polish..... If you use a MOP stay well away from the edges and use water, makes a right mess, don't get the panel too hot by keeping the MOP still.. move it all the time... Get a nice soft foam pad on the MOP... If you're not careful you will burn the paint or wear through it on edges, but you have to be brutal to do it on paint that is a few years old... Have fun.... __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior -Click here for Thread- 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click here for Project Fatty off roader- Last edited by Haylands on 25th Nov 2016 7:57pm. Edited 1 time in total |
Thanks for that buddy! Never actually knew this process existed! My body works ok but could be better..i was resigned for putting the fatty into a body shop ..i will read up on it and give it a bash when the weather improves...fattys covered in 2 inches of ice just now so probably July |
Had the same problem found it on you tube ,and restoreFX car care.looks too good to be true but have been assured a guarantee and after speaking to him again today informed can apply any further after market cleansers polishers and waxs although will not be required Full fat 4.2 Sc Full fat vogue 4.4 petrol Jaguar XJR super charged Porsche cayenne Tvr tuscan mk1 Bmw mini cooper |
looks too good to be true I feel petes way is better or a really good detailer I had a rolls Royce done cost £500 don't tell her in doors and its superb now |
