Home > Technical (L322) > Dead Battery |
Steve French Member Since: 12 Oct 2016 Location: London Posts: 1 |
My 2004 L322 Vogue overheated in France and arrived back in the UK (after 5 weeks in France) on Monday afternoon and was dropped off at the garage for me.
12th Oct 2016 12:39pm |
Hmb Member Since: 12 Jun 2016 Location: Essex Posts: 90 |
http://www.fullfatrr.com/forum/topic38460.html 2010 Overfinch 3.6 V8 FFRR gone yee haa
12th Oct 2016 1:06pm |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 818 |
Won't the key physically work in the lock? ______________________________
12th Oct 2016 1:30pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34949 |
^ that's a good point ... - .- -.
12th Oct 2016 1:45pm |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 416 |
If it's a 2004 model then the key should physically work in the drivers door...unless the linkage has become disconnected internally. Unfortunately it's a common problem that people only find out about when the battery goes flat.
13th Oct 2016 4:36pm |
Bit difficult if he can't get in to open the bonnet........ ______________________________
13th Oct 2016 8:01pm |
Jack it up and go underneath. 2010 Overfinch 3.6 V8 FFRR gone yee haa
13th Oct 2016 8:02pm |
True but my commando days are over ______________________________
13th Oct 2016 8:07pm |
Why go commando?? Even in the army we had reme and the op's post said it was at the garage. Sure they'll have an easy way of lifting it off the floor.
13th Oct 2016 8:10pm |
Mines on the drive and it's dark and wet, just brought back many memories. I didn't read that it was at a workshop, my bad. ______________________________
13th Oct 2016 8:30pm |
Try the side repeater bit. The fil got into his daughters one like that. 2010 Overfinch 3.6 V8 FFRR gone yee haa
13th Oct 2016 8:33pm |
pembsRR Member Since: 15 Oct 2012 Location: Wales Posts: 35 |
Clearly there's a good reason yours has gone flat in this case, however as a general rule, I think it's smart to change the battery at least every 3 y - there are so many reports of problems caused by low voltage, it seems to be to be fairly cheap preventative maintenance |
14th Oct 2016 6:13am |
