Home > Technical (L322) > rear wiper washer
alistairh
rear wiper washer
Ok second post on wipers/jets in 1 day Laughing My rear wiper doesn't release any water when its meant to...its been annoying me all day so upon further investigation I've opened upper panel in tailgate..the one that hides the mechanism and rf receiver...
there's a rusty deposit type stain on the plastic and a small collection of water...it appears to be coming from the point where the water inlet meets the assay...can I reseal this or is it simply a matter of buying a new unit?
Post #409785 18th Oct 2016 9:59pm
Take a look here - http://www.fullfatrr.com/forum/topic9924.html Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #409793 18th Oct 2016 11:31pm
alistairh
That's perfect...thanks!
Post #409798 19th Oct 2016 5:08am
miggit
Whistle You don't need the screws, when you've taken it apart, you can pop the old seal out of the black plastic bit.. The replacement seal will then sit deep in the black bit, and then you can glue it back in place with some epoxy resin (rapid works best, but get the cheap stuff from toolstation Wink )
Also the jets get very blocked on the arm, once the spoiler is off you can pop the jets and just test the water flow.. it should be like a cross eyed five year old Shocked , if not then the non return valve will be blocked ( 2" before the black plastic bit on the wiper motor) Yesterday I couldn't spell Engineer... Today I are one!
Post #409866 19th Oct 2016 7:05pm
alistairh
That sounds even better! Ordered some seals earlier from amazon.couple of quid delivered..will pick up some epoxy resin Friday and that's my Saturday task on the full fat..cheers again buddy Thumbs Up
Post #409881 19th Oct 2016 8:11pm
miggit
This is the stuff that I used http://www.toolstation.com/shop/Adhesives+...sin/p29905
If your going down the glue route you'll need something to degrease with as well, I use brake and clutch cleaner... which is industrial alcohol by another name Wink
Carb cleaner, Zippo lighter fluid (petrol) or cheap and nasty aftershave will do as well Mr. Green Yesterday I couldn't spell Engineer... Today I are one!
Post #409906 19th Oct 2016 11:58pm
alistairh
Just picked up the same stuff Thumbs Up Hopefully seals delivered today so I can get it fixed today...another job ticked off the to do list shortly! This forums great! Saved a fortune on repairs Laughing
Post #409937 20th Oct 2016 11:26am
alistairh
Miggit...it worked a treat buddy! Did everything you advised and the epoxy did the trick! Thanks again guys Thumbs Up ..
Post #410305 22nd Oct 2016 7:11pm
miggit
Your welcome Bud Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #410336 22nd Oct 2016 11:15pm
Earl of Ankh
England 2005 Range Rover HSE Td6 Cairns Blue
Having read this post and having the same issues myself I decided to give it a go. Washer jets now cleaned and working and the wiper arm lubricated and sitting nicely on the rear window.
New seal installed and no leaks onto parcel shelf.
Thank you so much for taking the time to put this post together so that RR virgins like myself can repair and enjoy these lovely cars.
Post #413219 12th Nov 2016 4:04pm
stu_007
2006 Range Rover Vogue 4.4 V8 Tangiers Orange
I was going to give this a go but ended up buying a complete new motor. "YYS" G4 FFRR
G4 2006 Thailand Support Vehicle - Fleet Number 81
Post #413268 12th Nov 2016 8:30pm
^ I think you wasted your money Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #413277 12th Nov 2016 9:17pm
miggit
Shocked Shame on you Rolling Eyes It really isn't much harder that a Blue Peter job.. only there is no sticky back plastic involved Rolling with laughter Oh the good old days... when there wasn't a safe Fairy liquid bottle in the land Laughing
I have always used the philosophy that you can't break it anymore than broken, but you might be able to fix it and save a fortune Mr. Green Works for most things... Rolling Eyes although I haven't had much luck with tyres Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #413294 13th Nov 2016 12:05am
builder1966
England 2004 Range Rover Vogue Td6 Adriatic Blue
did away with mine going though the motor and put dual sprays on mine and wow has made a great difference can actually see from back window when driving down really dusty sites
Post #413325 13th Nov 2016 1:36am
