Home > General > Degree warning
Degree warning
Every time i am out and about a message flashes up on the dash ( ping ) 4 degrees , always bloody 4 degrees never 3 degrees nor 2 degrees , always ( ping ) 4 degrees does this happen to anyone else , beginning to think the friggin brain in the car only recognise's ( ping ) 4 bloody degrees ............ Confused
Post #2604 26th Jan 2009 9:13pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
The geniuses at LR think this temperature triggers all sorts of natural dangers that you must be warned of... Would love to shut it as it always scares me, I think some fault is signalled....
Post #2608 27th Jan 2009 6:03am
ken
United Kingdom 2018 Range Rover SVAutobiography 5.0 SC V8 Santorini Black
Mine pings at 4 or lower
ie If I start it and it 4 deg its pings then no other warnings same if its 3 or lower one ping and its gone Thumbs Up
Post #2609 27th Jan 2009 8:34am
Larry
England 2006 Range Rover SE Td6 Java Black
My problem is that it's the same "Ping" sound as the speed warning, so driving along when the temp drops always has me quickly glancing at the speedo, assuming the speed has crept up again.
I presume it's because fog and black ice can form below that temp, although a Vauxhall I had gave you a warning below 2 Deg C, so it doesn't seem to be a universally recognised temperature.
Post #2613 27th Jan 2009 9:47am
kin
England 2006 Range Rover Vogue TDV8 Zermatt Silver
I got the "ping" this morning at -1 degree Smile
Post #2766 2nd Feb 2009 11:32pm
Soupdragon
England 2003 Range Rover Vogue SE 4.4 V8 Stornoway Grey
Mine 'pings' at 3C. and under. Assuming climate change continues its present path in this country, we're going to be deafened by the bloody warning over the coming years! Rules are made for the obedience of fools and the guidance of wise men.
Post #2864 8th Feb 2009 3:01pm
