Home > Technical (L322) > stall speed: what should be OK?
Rangie4fun
Austria 2013 Range Rover Autobiography TDV6 Barolo Black
What should be the correct stall speed (apply foor brake firmly, engage D or R and push accelerator firmly) for a 3.0 Td6?
Mine is 1500RPM max in D and 1300 RPM in R
What are your figures?
Post #410868 27th Oct 2016 7:42am
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
What's this in aid of? I would have thought it puts unnecessary strain on already weak parts e.g. Gearbox and torque converter?
Post #410871 27th Oct 2016 9:48am
miggit
^^time bomb and ticking come to mind Shocked
Raising the stall speed isn't going to improve the performance of a TD6.. the factory has got it about right, with the torque converter reaching stall at around maximum torque..... the only possible benefit of raising the stall is if you have fitted a larger turbo with lag... and you wouldn't want to do that cos the GM gearbox struggles with the standard power as it is Rolling Eyes
The biggest problem with the GM5L40E box is the slipping TCC mode that exists between 30 and 50 MPH... it eats the TCC which then wears the rest of the gearbox out Evil or Very Mad Yesterday I couldn't spell Engineer... Today I are one!
Post #410884 27th Oct 2016 10:29am
Checking the stall speed is a recognised way of detecting faults with a TC, in a well running box that is up to temp it does not harm the box to test it once or twice.
miggit, he didn't say he wanted to change it, he want's to know what it should be, you wouldn't raise it on a diesel 4x4 anyway, you can get a lower stall speed TC from Australia which should help if you tow heavy things (miggit, why haven't you got one,,??)
Sorry can't help with what it should be but your readings sound OKish I would say... Thumbs Up Pete
-Click here for Thread-
Post #410899 27th Oct 2016 11:13am
Stacker
Not sure where my negativity regarding my TD6 comes from, it never breaks Rolling with laughter
Ill give this a go when mines fixed, probably smashing the TC to bits in the process!
Post #410902 27th Oct 2016 11:28am
miggit
Pete I looked in to a super duper all singing and dancing H/D torque converter... and by the time I had paid for it and the shipping I could have had the gearbox rebuilt Rolling Eyes they ain't cheap... went for a totally new, never rebuilt one instead Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #410906 27th Oct 2016 11:52am
Thumbs Up Thumbs Up Pete
Post #410948 27th Oct 2016 5:12pm
Rangie4fun
thnx for your replies Thumbs Up
Is anyone out there who can tell what stall speed is normal for the Td6? I couldn't find any information on that in the RAVE manual.
I'm asking because the guy who did my gearbox overhaul has tested this thinks it is too low.
I have a strange problem: when putting FF in Reverse and pushing accelerator quite firm there is not much acceleration and it feels like the drive is skipping some teeth (as you can have with a bike when the chain is skipping some teeth). If anyone has any idea about that it is also much appreciated Bow down
Post #410978 27th Oct 2016 7:43pm
miggit
Yup Shocked but only going up hill backwards Rolling Eyes .... the transmission oil pick up is at the back of the gearbox.. and when you put your foot down too hard going up hill backwards, all the oil flies to the front of the box away from the pick up and causes starvation Shocked ... end result hiccup from the box Embarassed ..... it just goes to show how bad the design of the gearbox is to start with, let alone how unsuited it is for a 4x4 Evil or Very Mad Yesterday I couldn't spell Engineer... Today I are one!
Post #411030 27th Oct 2016 11:10pm
Rangie4fun
I agree with the design and just thought this was the cause of the problem, but then I tried it on a flat surface and the problem is exact the same Rolling Eyes When at idle it drives easily backwards, but giving throttle will make it hick-up and you feel it doesn't have as much torque as it has in forward Question
Post #411054 28th Oct 2016 7:37am
miggit
Low oil?
As the sump is sealed there is no easy way of telling if the level is too low, but I think that I'd be looking at that before I went looking for bigger problems....
Rolling Eyes And if you've had your gearbox worked on, wouldn't it be a better idea to make a trip back, and complain??
As you can see the oil pick up is at the rear of the filter, if your oil level is low then every time you go backwards your moving the oil away from the pickup point.....
FYI pic is of filter upside down oil goes in on the right and comes out the left tube, but up cos it's upside down as well Wink
In all honesty it's not a very deep sump.. most 4x4 sumps hold twice as much oil as the gm box.. it's probably something to do with economy, and not putting too much precious oil in the box... just enough to make it function under normal road conditions... not extreme off road Evil or Very Mad My Jeep takes best part of 2 gallons (8litres) of oil before it shows on the dipstick ..... Yesterday I couldn't spell Engineer... Today I are one!
Post #411079 28th Oct 2016 10:05am
Rangie4fun
indeed the design is not one of the best i guess... Rolling Eyes and in reverse i can imagine there's not enough oil flow, but the design does not explain the same symptoms when on flat surface....
I have been to the specialist who did the gearbox and he's very helpful in finding the problem with reverse hick-up. When i was there last week he drove the car and said it looks like my FF misses some horses. I didn't notice, but he was right about it: I had a loose vacuum hose on the turbo. After reconnecting I did another stall test: now 2200RPM in D (and that's what it should be regarding the gearbox specialist) and in R I stopped at 1400RPM because the hick-ups where very heavily (not really good for the box)
Just phoned with the guy and he's now thinking it might be in the valve block so he's going to contact the one who had supplied the valve block. Fingers crossed.
Anyone, maybe RRPhil, who has an idea why the reverse is hciking-up? Question
Post #411088 28th Oct 2016 10:33am
miggit
RRPhil knows enough about the GM5L40E gearbox to specialise in the ZF box instead Shocked There's a lesson there Rolling Eyes if someone who knows about auto's don't want to know Rolling Eyes
But I'm sure that he'd be able to give a better reason for it hiccuping in reverse other than it's a GM5L40E... although with it's reputation... that is a reasonable response Rolling with laughter
I know that mine will do the reverse hiccup when I go to see my parents, their driveway is a slope, 15-20%, and if I reverse out of the driveway too quickly I get the hiccuping box syndrome.. I just don't push the loud peddle too hard, it seams to work Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #411097 28th Oct 2016 11:05am
Rangie4fun
My gearbox re-builder wanted to exclude a valve block failure so today he installed a new one. It didn't cure the problem Big Cry
Twisted Evil
What can be the problem with the hick-up in reverse?? Any ideas most welcome Bow down
Post #414299 18th Nov 2016 9:31pm
miggit
I wonder if it could be pressure related... too much rather than not enough... like the pressure relief valve keeps on blowing... bit like a pressure washer with a semi-blocked nozzle Rolling Eyes Yesterday I couldn't spell Engineer... Today I are one!
Post #414311 18th Nov 2016 11:36pm
