![]() | Home > Technical (L322) > Help: ZF 5HP24 Transmission vibration l322 V8 2002 |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
The Rev counter bounce is a good indicator but only a slight fluctuation |
ohuntsman Member Since: 21 Mar 2016 Location: Cornwall Posts: 340 ![]() ![]() ![]() |
I just got a quote of £197 + VAT to recondition the torque converter.
Depends how long you intend to keep it, You may be ok with just the TC if you have the petrol 02-05 but I decided that I didn't want to be taking the transmission out again if i could help it so opted for the rebuild that i did myself but if you going to go for the rebuild and you have the petrol 5 speed ZF box then RRPhil sells the recon transmission and they are as good or better than new! and he also sells the recon TC as well as there are only certain companies that can effectively recon the TC. The diesel TC go due to the failing valve block which if not repaired will cause the TC to fail again at around 10K miles if you are lucky killing the transmission again. |
Who was the quote from and i take it that is just for an exchange unit and not fitted? What vehicle do you have? The way i determined the TC was at fault on my 04 petrol was to keep a constant light accelerating throttle up a long gradual incline and the TC used to vibrate up until around 55 - 60 mph at which point it should stop as the LUC should be locked and when i was getting the vibration the rev counter would move very slightly. |
I'll check it out as soon as my brake pads arrive from EuroCarparts' Halloween sale #noideawheretheygotdeliveredto
be careful jacking the back up with only a small amount of axle stand on the wood as when i jack up mine it moves around quite a bit from one side to the other, i use cheap railway sleepers and sometimes drive mine up on them |
Cheers buddy- I have plenty of sleepers |
Sussex Auto Parts |
They did mine and all good, JPAT also do them and PM RRPhil to see how much he charges for one already done off the shelf as an exchange i believe. |
Xray charlie Member Since: 22 Jul 2016 Location: Derby Posts: 48 ![]() ![]() ![]() |
holidaychicken, I intend to keep the car for a few years as it's a very clean '03 V8 Vogue in the colour combination I really wanted also I only want to do the job once so I'm leaning towards a fully reconditioned unit from RRPhil when needed. Currently the symptoms are not severe so I can live with it for a while longer. |
That was my thoughts with mine, the ZF5HP24 transmission is much more forgiving than the GM in the TD6 as when the TC in that unit begins to let go it takes down the transmission as well by pumping metal filings through it.
