![]() | Home > In Car Electronics (L322) > Electric windows |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 481 ![]() ![]() ![]() |
Not quite sure whats going on here, but changes the front struts and airbags on my car today and left the window open whilst I disconnected the battery, fired it all back up and the window wouldn't close (drivers only). Could hear the motor click to open, but wouldn't close.
With window up, and wires as they should be, doors closed, try a battery disconnect and leave it off for @ 1 hour. .
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I would put the wiring back the way it was, with the window shut, disconnect the battery, go down the pub, have lunch and an afternoon snooze and then reconnect... failing that just wait the 30 mins |
So in theory... I could just disconnect the battery for an hour, and then when I reconnect it should work?
I have noticed that there appears to be 2 relays in the wiring diagram you posted.. possibly one has gone down... but what is on the drawing what is actually there are 2 different things, as I suspect that LR will be using solid state relays (chips) to do the job... 1 cos they is cheap, and 2 cos they make no noise...... if that is the case then it will be a new module required... but hopefully the reset will sort it, they tend to get the hump when you mess with them and they do all sorts of silly things to tell you they have the hump.....
