1. wifi wont turn on from the menu. I have taken the unit out and the aerial is connected.
As a security feature, in some systems Wi-Fi is inhibited (other than as a hotspot) if there is a 3G/4G broadband connection. Could this be the reason?
2. when you plug a ipod into it. It will only display the name of the ipod and no music.
How are you connecting the iPod? Presumably through a USB connection. When I asked at Erisin they said that the head unit does not support iPod, so I suspect that the only way to get music in through USB would be using a third party generic app.
I have connected my iPod through a dock direct to the DSP.
3. when you get a incoming call it only displays the number and not the name.
Have you sync'd the contact list between phone and head unit?
4. I would like to change the colour of the display to green.
I presume by this you mean the backlighting of all the buttons around the display? If so, Home>Settings>Elements enables you to tune the RGB backlighting to suit your car.
5. also where have people mounted the mic for the hands fee?
At the top of the O/S A pillar where it meets the head-lining.
HTH
