Home > Technical (L322) > Td6 temperature gauge
Imbigt
At what position should the needle sit at when hot Question
Post #411955 3rd Nov 2016 9:56am
12, o'clock when up to correct temp... Thumbs Up Pete
Post #411957 3rd Nov 2016 10:53am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
About 5 to 10 to recently, as it's got colder.
But then even in the summer, it never goes over 12 o'clock.
Post #412005 3rd Nov 2016 8:30pm
Zulu 10
Beware that the needle position is not a direct feed from the coolant sensor: instead it is the ECU's interpretation of the value produced by the sensor.
My Td6 was showing normal - i.e. needle half way up the scale, but the coolant temperature when read digitally from the OBDII date stream was never exceeding 80ºC.
Consequently I changed the thermostat and now the coolant temperature is around 92 - 93ºC, but lo and behold the needle is in exactly the same position.
Funnily enough my fuel consumption has improved now that the engine is in its optimum operating window, and the heater is far more efficient.
Post #412018 3rd Nov 2016 10:02pm
All modern vehicles now have gauges that do what the maker thinks you need to know... Not sure on the TD6 but the M62 get's to normal at under 80 degrees and then doesn't move off normal until the temp gets above 115-120 deg a bit useless for measurement like an old gauge, they may as well just have a light... Rolling Eyes Pete
Post #412029 3rd Nov 2016 11:30pm
wayneg
Once warm mine sits squarely at 12 oclock but its not always been that way. When I first got the car the gauge was always on the low side, dropping lower when I was on a long run. After researching here and investigation I found the EGR thermostat was knackered, stuck open. Fitted a new one and now all good. Simple fix if thats your issue. This vid will give you an idea, not exactly the same, ours have a different hose fitting.
https://www.youtube.com/watch?v=P7VFfaXSSso 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #412037 4th Nov 2016 1:48am
miggit
Whistle I can say with confidence that normal starts at 60 and goes over 100 degrees as I have a proper temp gauge on my ffrr too... so if your gauge isn't getting to the 12 o'clock position I would suspect that you thermostat is in the open all the time, or fubar mode Shocked
Oh and Pete not all modern cars suffer from an ecu temp gauge.. my other tractor the gauge goes up and down like a yoyo... unless there is an intermittent wiring fault Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #412051 4th Nov 2016 9:46am
Imbigt
After 10 miles driving
Post #412122 4th Nov 2016 5:14pm
miggit
If that is where it sits after a run then I would say that it is a bit low on the temp.... However it could be the gauge... the needle might be in the wrong place..... I would suggest that plugging in a IID tool might be a very good idea, as you can see the temp that the ECU is seeing...not what it thinks you want to see.
Failing that then either a laser temp ray-gun thingy, adding an extra gauge or a trip to an indy, would help diagnose the problem... But if you don't already have one a IID tool will be the best investment.... it's a bit of a Shocked when you see the price, but trust me they are worth every penny Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #412144 4th Nov 2016 7:29pm
Imbigt
I will plug it into my launch what should it read in relation to the gauge
Post #412150 4th Nov 2016 7:54pm
miggit
Well normal should be around 75 - 100 degrees centigrade, as long as your over 70 then I wouldn't worry, if it's below then I'd be looking at the EGR thermostat and then the engine thermostat... but the EGR one is way easier to get at Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #412155 4th Nov 2016 7:58pm
Imbigt
Yes but eBay don't have them listed
Post #412166 4th Nov 2016 8:24pm
Search for item 11712247723 on eBay. Thumbs Up
Post #412168 4th Nov 2016 8:48pm
gregdav
17 mpg Shocked
@ndf Thumbs Up
Post #412170 4th Nov 2016 9:10pm
Imbigt
I don't hang about Rolling with laughter
Post #412194 4th Nov 2016 10:26pm
