Home > Technical (L322) > Td6 temperature gauge
Zulu 10
miggit wrote:
Well normal should be around 75 - 100 degrees centigrade, as long as your over 70 then I wouldn't worry, if it's below then I'd be looking at the EGR thermostat and then the engine thermostat... but the EGR one is way easier to get at Wink
I fully agree about changing the EGR valve, but if you've got that far then you might as well do the main thermostat at the same time.
I understand that borewash on a diesel is of less significance than it is on a petrol engine, but are you seriously advocating running an engine outside its optimum operating envelope?
I for one would not want an engine which is permanently over-fuelling - it's not only the cost (I'm 2 mpg better off having changed both thermostats), but the potential for (however slight) dilution of the engine oil.
At the risk of sounding brusque: why do you think an 88ºC thermostat is fitted?
Post #412337 6th Nov 2016 9:47am
miggit
^^ well in an ideal world the thermostat would hold the engine at exactly the correct temperature...... But in reality the operation of a thermostat isn't quite so quick.....and this is why the temp goes up and down like a yoyo... hence the statement 75-100 deg should be ok. As you correctly say 88 deg is the correct operating temp.. but I can guarantee that if you monitor what the ECU sees it will only be 88 a fraction of the time. This is why in the good old days Smiths damped their temp gauge to stop the needle dancing up and down, and why LR has opted to rate normal on the ffrr between 70 and 105... it's actually more than that, I think it shows normal from 68, and mine was still showing normal at 105, so that will go higher before the needle moves Shocked
I fitted an old fashioned style gauge cos I'm doing extreme towing with the car and I really need to know when I'm pushing too hard.. been a bit paranoid after owning a Shogun, which would boil over and then show hot on the gauge Big Cry I dare say that LR have improved on the system, but I wasn't going to test it Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #412343 6th Nov 2016 10:58am
Zulu 10
Having watched the ECU reported temperature - and with the benefit of the tell-tales in the Torque app - as I did a 650 mile run across France a couple of weeks ago I can report that once warmed up the temperature remained between 89 and 93 for the whole journey. Actually even though I agree about latency in the thermostat, I can't see how all that metal and coolant could go up and down "like a yoyo" across a twenty five degree range.
On my Jag which also suffers from ECU interpretation of both coolant temperature and (worse still) oil pressure I've fitted a piece of American kit called 'Real Gauge' which piggybacks onto the sensors and drives the needle stepper-motors.
The temperature variation is pretty small - 90 to 94 from memory even in high 30s OAT.
Obviously the oil pressure varies hugely, as one would expect, and apparently that's the reason why JLR took the decision to fit a 'numpty needle' which shows normal as soon as the 6psi switch closes: because they didn't want the hard of thinking class of owners troubling the dealers with the complaint that the oil pressure keeps going up and down.
Post #412349 6th Nov 2016 11:49am
miggit
"I can report that once warmed up "............
Once my real time gauge shows 68 deg the ffrr's is stating Normal... As the engine temp increases it still reads normal, even at 105 deg Shocked Once my engine has got 88 deg it doesn't really go below.. but with a steep hill and a 3.5 ton trailer the real time gauge will go over 100 easy...and all the time the ffrr gauge says normal Rolling Eyes It's a great bit of kit to stop the numpties complaining about the needle moving, but in real world applications, it can be left a bit wanting. Shocked
Also the temp sender for the real time gauge is in the top hose, so it shows a greater range of temps during opperation.. But the water has to get to that temp for the gauge to register it Rolling Eyes
The OP was asking if there was something wrong as his gauge stays at 11 o'clock not 12... I was only pointing that he didn't have to thrash the nuts off his TD6 to get it scalding hot to test the gauge.. as long as the ECU is seeing temperatures in the 70's + then the gauge will point to normal.. unless the needle is in the wrong place...... Yesterday I couldn't spell Engineer... Today I are one!
Post #412351 6th Nov 2016 12:09pm
Imbigt
How did you tap into the top hose to fit the sensor Question
Post #412357 6th Nov 2016 12:27pm
Zulu 10
Demon Tweeks sell this:
http://www.demon-tweeks.co.uk/performance/...daptor-kit
but as with with most things that they sell, the same thing is available cheaper elsewhere
http://www.ebay.co.uk/itm/Alloy-T-Piece-Te...1558189933
Post #412362 6th Nov 2016 1:37pm
miggit
Whistle I used the second option.. but I don't think that I paid that much Wink FYI 36mm is the magic number for a TD6 Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #412367 6th Nov 2016 2:23pm
If you have to faff with the egr cooler and stat just remove them. Much simpler and better in the long run for your engine above just possible diesel oil mixing FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #412581 7th Nov 2016 8:24pm
Imbigt
Ive ordered an x type jaguar fan pack with the soft start ecu I'm going to fit a new thermostat and remove the egr cooler completely and see what happens. Thanks for all the replys
Post #412596 7th Nov 2016 9:45pm
miggit
Further to my previous quote where I stated that "Normal" is from 68 deg.. I would like to amend that to 72 deg Embarassed Due to the cold weather it actually took a few minutes to warm up and I was able to determine the exact point at which normal was reached Very Happy Yesterday I couldn't spell Engineer... Today I are one!
Post #414400 19th Nov 2016 7:31pm
