Home > Technical (L322) > Abs light and soft brake pedal.
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Hi
2006 td6 150k km
Changed pads pedalnl still soft and abs light turned on after abs kicked in prematurely as braking normally and car did not slow.
Luckily no problems.
Post #412011 3rd Nov 2016 9:18pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Sounds like air in the system somewhere as air is compressible (hence soft pedal) where as fluid is not. It can also effect the ABS operation.
Try bleeding the brakes or changing the fluid if it hasn't been done for 2 years.
Post #412032 4th Nov 2016 12:29am
Do you live in a "wet" state that has lots af rain? Your brake pipes could be corroded and leaking. Have you seen any drips of brake fluid at all? Got - 2017 SDV8 Autobiography in Loire Blue
Post #412035 4th Nov 2016 1:10am
StewD
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Java Black
Sounds like you changed the pads hoping to cure a soft brake pedal...? If I read your post correctly.... System needs bled which is a simple job. Current: Supercharged 06 FFRR in Java Black
Previous: BMW 740D M Sport
Previous Previous: BMW 730D Sport
Post #412044 4th Nov 2016 9:04am
umitbat
Thanks for answers.
Pads were gone so i hoped itbwould also cure it.
Yes i live in a wet city and car was stationary mostly
And also suspension fault message chimes time to time after pads are changed.
Post #412046 4th Nov 2016 9:13am
