![]() | Home > General > Petrol in a diesel - Eejit!! |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
I've used a similar mix, on a diesel van, and it drove fine. The only real problem I was told, is that the solvent action of the petrol, can mean that the pump possibly could be damaged, as the oiling of the diesel fuel is self lubricating.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8134 ![]() ![]() ![]() |
I'm far from an expert, but I'd run it - but keep topping up the tank with diesel to further dilute |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1881 ![]() ![]() |
The Td6 is more tolerant of a splash of petrol than the V6/8's, but keep it topped up with diesel just to help dilute it as much a spare possible
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591 ![]() ![]() ![]() |
Thanks Chaps, made a call to a friend who is a dealer and he reckoned I would be OK, hope this is not a senior moment as I am only 22 (in my head) |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35872 ![]() ![]() |
you probably cleaned the injectors doing that ...top tip |
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
Like the others say,it is not a problem with that amount |
Thats what I had heard Stan but obviously not something to try, thanks for the replies guys, ![]() |
janderson41 Member Since: 26 Jan 2012 Location: Scotland Posts: 14 ![]() |
I would also put a bottle of 2so into a full tank of diesel.
As do I |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
me to |
JohnJ Member Since: 22 Apr 2016 Location: Varese Posts: 41 ![]() ![]() ![]() |
I did it two times |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 570 ![]() ![]() ![]() |
Sounds like you may have got away with it.
2004 TD6 - if you hover over the little car symbol on the left of the posts, it tells you |
Bugcos Member Since: 18 Jun 2015 Location: Stoke on Trent Posts: 24 ![]() ![]() |
Did this in a lorry a few years back. Looked up an had put 105 litres of petrol in |
