![]() | Home > Technical (L322) > Alternator? |
| Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2951
Battery light started flashing intermittently this morning. Just plugged in the IID and it's showing 11.4 volts and doesn't increase with revs. I'm guessing the alternator has gone.
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35882
the smell is the diesel , the alternator should ideally push out around 14.2 volts.. ... - .- -.
This isn't a diesel smell Stan. Nothing like |
| mzplcg Member Since: 26 May 2010 Location: Warwickshire. England. The Commonwealth. Posts: 4029
Sounds like the smoke has escaped from the alternator. Take it to a place where they can put the smoke back in. |
| Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1673
Disconnect the battery as a damaged diode back can short the battery and kill it pretty quickly |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
^ You don't need to change the alternator and battery together.
| Boodog Member Since: 23 Mar 2016 Location: Wales Posts: 5
Thanks. New alternator |
| Weejock Member Since: 30 Dec 2011 Location: UK Posts: 419
Boodog,
Thanks for such a comprehensive reply Weejock. I went for a 3rd opinion today with our local tyre/exhaust/battery dealer and they said same as National Tyres and yourself so I definitely won't be going down the new alternator route until I've checked everything else including charging the battery and the testing. The car is a 2003 4.4 V8 petrol. My wife uses it but only for local runs averaging around 8 miles from start to stop (home to shops) and given the quantity of electrics and electronics on the RR I suspect the battery isn't getting sufficient charge between start/stops.
| ohuntsman Member Since: 21 Mar 2016 Location: Cornwall Posts: 341
Have just replaced our battery in the Black Friday sales and have ventured into the cold harshness of the north- all seems to be much better now...... |
| All times are GMT |
