![]() | Home > Technical (L322) > maybe being a bit paranoid but..... |
If it were me I wouldn't have left an engine idling for an hour, it doesn't do them any good. take it for a blast along the motorway and see how it is after that |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 ![]() ![]() ![]() |
With it sitting on idle the water vapour has probably pooled in the exhaust - a blip of the throttle will blow it out as steam .. as 47p2 suggests get it warm with a blast then see what it does
Just had her out for a good hour around the bipass..all good now...what I did notice before I set off was a sound of water inside the exhaust back box..as you say its been steam! The noise must have been the steam being forced out causing panic within |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
Expect on cold mornings, to have steam out the exhaust. It re-enters as you car cools down. And it reboiled out etc.
Thanks for input...seems to have been a huge build up of water in the backbox..very pronounced sound in fact! Never realised so much would build up in an hour if I'm honest...there was so much that when i blipped the pedal the noise it caused sounded like some sort of backfire...I'm quite relieved now.. |
