![]() | Home > Technical (L322) > what pressure ? |
I run 42 rear, 36 front on 20" Alloys ...... |
Do the Chalk test. Needs flat, clean tarmac.
David Member Since: 15 Oct 2010 Location: Murcia Posts: 301 ![]() ![]() ![]() |
anyone else ??????????????????????????????????????????????????????????? |
The pressures on the car are only for guidance and have to be higher than needed for Land Rover to cover themselves from any litigation etc.
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 413 ![]() ![]() ![]() |
The first ones on the label have the marking of less/more than 160km/h.
Recommended pressures have varied by year of manufacture. One of the things that should be remembered is that the centre diff is designed to allow only a certain amount of slip. due to different rolling circumferences of front and rear tyres.
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Just checked my tyre pressures, and they were 29psi in the front and 33psi in the rear. So I've pumped them up to 36 / 42 as per the label on the door shut.
